For Sale PRO Built FJ40 Crawler -- Insane
Awesome 4X4
1975 Toyota FJ40
Trailer Additional.
Smog Exempt, Never needs to be smoged!
Pro Built
Has Everything
Less than 10,000 miles on everything.
Tuffy Security Lock Box
Cross Over Shock Towers front and rear
Extra large remote Reservoir King Shocks
Extra filters plumbed in for everything
Mostly Heavy Duty Braided Hoses used for all hydraulics and fuel with all AN Fittings
Custom Pro Done Wiring Harness
Optima Yellow Top set up for future Dual Battery Setup
Warn 9500 i Winch with remote cable operator
Cargo Rack Tiered in rear inside
Custom fuel Tanks (aluminum Pro built)
Insulated front and firewall with heavy rubber matting
Full cage roll bar including under front seats
Custom Dana 60 Dynatrack Axles High Pinion Front and rear with 538 Precision Gearing Built 4-inches wider than stock and wheelbase stretched 6-inches.
Aluminum Diamond Plate side body trim and wheel wells opened up for extra large tires and wheels with flairs in rear.
New front window
ARB Air Lockers Front and Rear
1 Ton Chevy Hydraulic Brake System
2 high efficiency Hydraulic cooling systems with Spall 12-inch fans
(Power Steering & Auto Trans Cooler)
AGR Custom Steering Box (Close Ratio-Power) and a Hydraulic Rock Ram Power steering Ram.
Lee Precision Power Steering Pump
Racing Griffin Al Radiator with two Spall 12-inch custom high efficiency fans (custom AL welded shroud).
March Billet Serpentine System
383 Chevy Crate SB Stroker FI
Dart AL Heads
165 amp alternator
Ceramic Headers
Somewhere around 400 hp, nice rumble to engine sound.
3-inch rear exhaust with front crossover
Bead lock 38.5 X 16 on 15 inch Champion Beadlocks
Super Swamper Tires
4 wheel disc brakes with E-brake
Custom Tire carrier, Hitch, Tow Bar
Pro built 5K 700 R Overdrive Trans with elect. Lock up $X$ Truck Case
Full light Gauges
Art Carr Shifter.
Custom headlights
Custom off road seats with Simpson 4 point harness
Custom Fuel system complete
Giant Viair compressor built in with storage tank and plumbed to run air tools
Atlas II Billet Transfer Case
Hi-Angle Pro Built Drive Lines F&R
Optima Battery and much more
Surface Exploration Vehicle sold as is where is no warranties implied.
Cash sale of $ 33,500.00
I am in Temecula CA
Who did the work?
Off Road Unlimited in Burbank CA did the Dynatrack axle / Driveline conversion / Rock Ram / AGR tight ratio steering box.
The front reverse shackles even have delrin slider pads.
The CV joint on this thing is absolutely huge and bullet proof.
Amazingly tight Pro done setup.
No disappointments on this rig.
This rig turns tighter than any other 4X4 I have ever owned including my built willys
I have between 45 and 50 K into this rig.
When ever you pull over, folks always flock to this machine.
holy picture size batman.
how bout you smaller them so we don't need multiple screens? still looking for the trailer to which you refer.
also curious about Hi-Lift location, as was previous poster
Trailer reffered to
Gently used like new Tentrax off road camping trailer.
You can find the manufactures website simply by internet search for "Tentrax"
Custom paint
Roof Rack,
Custom removable (Jeep style holders) aluminum construction tongue box
2 tongue storage racks
Heavy Duty factory upgraded 3,500 pound off road torsion bar articulating axle
Custom Gas/Water can Rack (rhino Lined)
2" Heavy Duty receiver.
3 rail heavy wall 2" box tubing frame construction.
Plenty of clean storage inside fiberglass tub.
Nice rack on top of trailer for surfboards, small boat, canoe, or ????
Sealed lid/dust and water tight.
Oversize factory rain fly.
Sleeps 2 easily and is very soft on marine grade foam.
Recessed Jeep tail lights.
Factory Lift performed to accept 40" tall wheels and tires.
Solid one piece fiberglass tub construction. This thing is almost bullet Proof.
Grab Handles/Roll Bar
Factory Skid Plate
Custom wheels and electric brakes (need to be wired in)
Wheels are 37" tall and I think 12" wide Pro Comp All Terrain in very good condition.
This Trailer is truly like new.
There is over $ 10,500.00 invested in awesome HD off road camp trailer.
Factory hitch set up.
Added Heavy Duty removable pipe jack to tongue with 6" wheel.
Wheel pattern currently installed on the trailer is the Chevy/Toyota 6 bolt wheel pattern (6 on 5.5).
Wheel lug pattern can easily be changed to match your tow rig so you need only carry one spare tire.
This trailer is ready to go anywhere your rig can pull it.
Trailer weighs 600 lbs, pretty light for where this thing can go.
These trailers are currently still being produced at a rate of approximately 35 a year. Not very many.
Dealer stocks all repair parts.
This trailer has been stored in my garage since I have owned it and it has only been used for maybe 7 off road trips.
I am sure I forgot some stuff, but this trailer is great.
Permanent trailer registration so currently registered
No more sleeping in the dirt or on rocks when out there.
Please do a internet search for Tentrax for more information on the trailer
Looking for $ 6,500.00
I'm in Temecula CA.
