Primer pump removal & install
Perkasie, PA
Hi all, need some help here. I had my injectors rebuilt, & we have air in the system (our fault). So we were trying to bleed using the primer but that failed & started leaking, new Bosch unit on the way. Well we had to remove the whole unit to get it off. This maybe a stupid question but I read somewhere that it won’t fire if there no oil in the unit? How do I get oil in the primer housing before I start to fix the air in the system? I have 1977 HJ45 with the H motor from Costa Rica.
Engine oil to the injector pump is supplied by a small rigid line from the oil filter housing. Liberally pre-lube your lift pump before reinstalling, with the new primer pump on top of it there's nothing more you need to do with regards to 'oil in the unit'.
Crack the bleeder nipple on the fuel filter housing and start pumping on the primer until you get good steady spurts of diesel with each pump. Close the bleed nipple and start the engine.
Ok thank you for the reply, when you say pre lube the lift pump are you referring to the primer pump housing? If so can I just pour in the top before installing the new primer pump button? I really can't see any other way to pre lube without it pouring out during install. Thank you for any help, I gotta get her running again.
There's three "pumps".
1. The injection pump
2. The lift pump
3. The primer pump
The primer pump is screwed into the top of the lift pump, the the lift pump is bolted to the side of the injection pump.
If you've just removed the primer pump, screw the new one in, job done.
If you've removed the lift pump (in order to change the primer pump more easily) then smear a bit of oil on the mechanism and reinstall.
If you've removed the injection pump (unlikely) then seek further advice.
