Primary coil resistance
Canada
I've been having some problems getting my FJ80 started, so I went through the EFIdiag.pdf. The CEL light is on, and the other tests past, so I went on to test the coil.
Testing the Primary coil resistance, I got 0 ohms... while the spec listed was 0.41 - 0.50 ohms. However, I am getting spark. I'm not an electrical guru by any means. Is it okay that my primary coil resistance is 0 ohms if I'm getting spark??? Can I assume the coil is not the problem?
Well, ends up the primary resistance wasn't 0, I just needed to put my ohm meter on the right setting. Coil was still out of spec on secondary coil and a new coil from Toyota solved my crank and no start issue. Interestingly the bad coil was aftermarket.
