Price Advice...
Calgary, Alberta, Canada
*This was originally posted in the 60's section as I don't believe it belongs in the Classifieds/wtb. It was recommended that I post it over here...*
Hey All,
So I am planning on sealing the deal on a 84 Bj60 sometime this evening - I was hoping to get an idea of where I stand price-wise [see if I'm way out to lunch or he is].
-Its bone stock 3b/h55 with 185k, seems to run pretty good. Trans is a bit dodgy between second and third but synth fluids might clean that up.
-The cancer has got through the body panels in a couple of places - rear tailgate sill, running board trim, the leading edge of the rear wheel wells. Theres minor bubbling elsewhere.
-The frame is solid, however with a fair bit of surface rust.
-Front Knuckles are a little crusty, but steering is solid and 4wd system is in good working order.
-The interior is pretty sloppy - a couple of tears here and there and in need of a serious cleaning. Couple of busted vents. Driver's door latch is busted.
The guy is asking 6000 CDN which seems awfully steep to me considering the shape it is in. I understand that I have to pay a bit of a premium for a 3b/5spd- I was looking more in the range of 4 - 5.
I appeciate any thoughts or advice you might have on the subject.
Cheers
The Kms sound low.
I paid 10k for mine about 4 yrs ago. It had a decent frame, and no visible body rust. Only a few blisters that were sanded down. No holes. My odo was 227k KMs. So fairly low klicks.
Personally have a really good look at the frame. Some of them can be downright dangerous at the back half. And not worth fixing.
6k is a lot of money for just the engine.
If the body is really rusty it takes a lot of work to repair. I have been doing that for the last 2 yrs.
I paid 6500 for an absolutely rust free 80 series(gasser) That I plan to install a diesel in.
Looking back on my BJ60 purchase I may be inclined to buy a donor engine(diesel) and install that into a rust free Fj60 from the USA.
But if that one has a solid frame and the engine is strong with those low kms I might be inclined to think its worth 5k... as long as you can live with the body rot.
For a 5k investment there is not many other cars out there that will deliver as many cheap miles and still be worth something down the road.
What else does 5k buy?
$6000.00 seems high IMOP...she sounds pretty rough, for that much money you could buy a fj60 alot cleaner and find a donor bj60 for 2-3000.00 and have alot less work.
Check the frame on the rear where it cuves up and over the rear axle...put your finger in the rectangular opening in the frame. If it is full of dirt I bet you could drive a pin punch through the frame with a good hit from a hammer!
Hard to shift tranny could be VERY expensive to fix...oil changes seldom fix that problem.
Landcruisers are great rigs but you will be spending at least a couple of grand just to get her up to snuff. IF there are no major problems!
Minor bubbling means HOLES... mine had that...
I rebuilt both rear doglegs fixed both front fenders(holes) painted and it still cost 1200.00 with me doing everything except spray..that cost 500.00 including paint. I prepped and primed.
just my opinion, and stuff I have learned after 8 years of owning one!
Daryl
Unless you have another car/truck to get you around or you don't need one right away, you should be weary. This truck will likely run a big bill or lots of your own time. The key for saving on repairs on those trucks is not needing the parts "right now" kind of thing. You'll find parts, bits and pieces some real nice folks that feel for you etc ... Providing you don't depend on that truck.
Where about are you, I am in Guelph. I can lead you to a shop where they can lift the truck sand blast the undercarriage, epoxy prime it and paint it. Short of that, you'll be playing hide and seek with the damn frame rust. You also need (as mentioned above) to purge/flush the frame otherwise it's rotting from the inside out.
This shop has done all the work on my truck as in birfield and transfer case rebuilding(basically changing the seals and gaskets) for an honest price, plus they are familiar with it now. It might help you out.
As to body rust; Little rust means way more rust than you think.
The transmission issue, hmmm that'll scare me. I was reading earlier of a "mudder" taking the transmission apart with the intention of repairing it and ended up looking for a new one because it was a "one big mess". Otherwise, you can put a purchase condition and pay for the oil change to synthetic (if that is what you think will fix it) and see what happens. You know if it gets fixed or the owner gets a new oil change. Likely worth a hundred or more.
As to the price; "drop a bomb" I don't think it will be sold overnight (at least I doubt it). They are great machines but a "tractor in disguise" just the same. How many "Urbanites" you think would try it and go ahead and buy it? (not too many) . I often speculated putting a sticker up ; "0 to 60 3minutes" or "John Deere in disguise" or just a John Deere sticker :)
Hope this does not sound negative. Good luck.
the tranny shifting could just be the stick nylon seat under the shifter(try lifting the shifter up to see if it improves) also the tranny could have too much oil in it from the transfer case pumping it's oil into the tranny. Neither worth condemning the transmission. I doubt the trans is worn out with 185k kms.
Thanks guys, I really appreciate the advice.
Erabadj, I am located in Calgary - a long ways from guelph, but I appreciate the offer regardless. I look forward to doing as much of the work as possible myself - when I do get a cruiser I plan to keep it for a Very long time and build it into something that I can trust.
That frame purge/flush, can that be done without a body-off? I've heard of people oiling the frame - i presume that is done after a flush - what does this entail?
As for the immediate future, I would use it as a camping rig / dd [for what little daily driving I do] while trying to minimize the spread of the cancer - grind out, weld in, prime, etc. and other minor chassis and drivetrain rebuilds - basically slowly bring the truck around till i have the time, money, and garage space to wirewheel and epoxy the frame, and put a lift under it [next winter by the looks of things].
Cheers
Shifting
For a little more information:
Its only the shift from 2nd to 3rd, where the trans simply wont go into 3rd - you have to back off a bit, then try again, sometimes a third time. Is this the synchros between 2 and 3? Ive heard that dropping the oil and putting in synthetic [not a bad idea at 185K anyways] could clear this up.
if your truly concerned about the trans ask in the 60 section. There is some really expert H55f guys in there.
frame flush,
Cheers
A good compressor with a blow gun and a long nozzle (basically a brake line brazed on a brake fitting that will screw onto the blow gun nozzle), lots of time, and you start moving the dirt around by blowing through the frame holes, until you get rid of the whole residue inside. I went further and ran a chain through the passenger side frame rail and kept on pulling it to rub the scales off the inside. The driver's side however is not feasible unless you pull the four bolts that hold the steeing gear box in. As to grind it etc ... that's a lot of work for little results, sandblasting or whatever media blasting it is what I recommend. It'll make your rig look amazing (Three years later, people ask me if I put a new frame on).
I oiled it after, still do.
I take it you brought the truck home :) . Cheers.
Cheers
For the first part..... buy the absolute best cruiser you can afford then. You want to keep it a long time.
The frame is really hard to clean internally. I have tried with a pressure washer. I think the best way would be to lift the front up till the bumper at the back touches and stick a hose in the front of the frame to push the dirt back.
The front is normally cleaner, so spray front to back.
Oiling is done after it drys by spraying oil in all the holes of the frame and on the outside.
Pay someone to do it, like Krown.
Cheers
A thicker oil may help,but an owner with bad gear shifting habits can fawk the synchroes in these pretty quick.
They can keep going like this for a long while if you can be patient shifting gears.
I would use it as a bargaining point;)
Hey All,
Cheers
6 grand is too much. It sounds like the cruiser is in poor to fair shape, rust wise. The only thing going for it is the low klicks on the engine.
It sounds to me that it should be around 3,000.
If you are still interested, make an offer.
cash talks
in my experience cash talks.
I have been in a dealership with a $7,995 price sticker and walked out the door paying $5k total, taxes included. they even told me no twice before i talked them into it.
I saw lowball the seller, bring $3-4K cash and walk if they don't go for it. Who knows, as in my case i started walking after informing dealer I had $5k in cash on hand and they yelled for me to come back and gave me the price i wanted.
Worst case scenario you leave with your cash and keep looking for a good truck, cause for $6k you have a lot of options.
good luck!:beer:
