After replacing the head gasket on a 93 (previous owner stated head gasket was blown) vehicle still will not run, has fuel, spark and bang. Did a leak down test today and verdict is C1,2,4 and 5 all leak to the valve cover, oil, gasoline and metal shavings present on new sparkplugs. C3 was clean and held pressure and I didn't see any reason to bother testing 6 by that time. 30psi on C2 actually pushed the piston down...
Since the engine has not been ran since the head was machined I'm chalking the metal shavings up to that, gasoline is probably from chasing spark problems the last few days and oil... I'm giving that to piston rings.
Does anyone else see a culprit other than bad piston rings for this? Oil in the cylinder and air flow from the cylinder into the valve cover?
P.S I'm looking at S&J Engines for a rebuild. Any thoughts on that or are there any business on here that would be interested?
