Pressure pressure sense location on vortec
Santa Rosa, CA
On a 2005 series 6.0, where I can I put a sensor to monitor fuel pressure. Is there a spot on the rail that it can go? I can't find one. This is a version with the regulator and return line at the fuel rail.
I think you're going to need to plumb something inline. Just make sure it's on the pressure side and not the return (obvious, but you never know).
That's what we were going to do. But I thought there had to be a spot or dingus we could connect directly to the rail.
my 6.0 is a 2002 with regulator and return off the fuel rail, the gauge goes onto the RH fuel rail there's a Schrader Valve fitting to attach the gauge onto, don't forget to remove the valve when you put the gauge on
I wish I had seen that a month ago.
