preferred look for a slider
lcwizard
Supporting Vendor
Supporting Vendor
Miami, Arizona
Website
www.4plusproducts.com
What would be the preferred look for an 80 slider. Flat or angled?
Even though you gave 2 choices... your going to get 20 different answers.
I have family, so I needed the step slider option.
Theres merit in both and I think you'll see the 80 crowd has a couple options demonstrating each.
That said, make sure it's full length and offers some sort of flare at the end. Plus a nice angle on the main frame to go up and over rocks.
Someone posted a "boat slider" a long time ago that got some traction. The guy that came up with them made a handful of them but never turned them into production.
Generally speaking 2 different ones. High tucked angled for the rock wheelers and flatter more like step sliders for the occasional rock wheeler with family or what not.
Both will essentially have the same clearance . The mounts that weld to the 2 1/2 square tube are notched at the pinch weld so they can be tucked higher so the only difference will be tube on the outside. Maybe the angled will get you a little clearance on the outside but it would have to be a very specific situation. On both the outside of the 2" tube is about 6" from the square
That looks really nice. I have a family and recently bought a pair of OPOR's sliders, primarily due to lowest price available to my door. I would have preferred a flat slider for my wife and kids, but in the end cost won out and I got an angled set. Just sharing my thoughts as you appear to be doing market research. Good luck with your project. It looks like you do high quality work.
We've built 80 parts for about 17 years. We just never focused on them. The 40 parts ruled from 1990 to about 2007. We got into 60 parts in 1995
and they got better for us as time went on. For us, we got into the 80's too early. In 1998 people weren't as willing to modify their trucks. Our first swing out rear was in 2000 but didn't go well because it involved removing the rear cross member. We marketed lower control arms made of
2 1/4 x .375 wall DOM, upper adjustable and front and rear adjustable panhards. All were made from heavier stock than most on the aftermarket.
The imported stuff just sold better. Weaker but cheaper so we backed out of the 80 market waiting until it matured. Now with the used market more affordable it seems there are more interested buyers.
Our first intro into the 80 rear market 16 years ago
Additional thoughts: kids feet, dog paws, etc may be a consideration of some folks buying sliders.
Also, that's a sweet rear bumper! That'd be a nice alternative to what's out there. one that's not as bulky as a Slee or worse, an ARB, but still has great functionality and girth without being too low profile. Thumbs up
Since you asked for angled vs flat, i'll give you my opinion ;)
img_3439-jpg.1209766
This is looking from the bottom of the slider up towards the vehicle ? I would think you would want the flat sections with the ovals in them to be on the top of the slider. Otherwise you are creating something of a pocket for little kids to roll there foot down into. Just a thought, of course I can't see what you've got going on the other side. The overall design is quite pleasing to the eye and looks very stout.
As far as angled vs flat, I prefer angled myself for the advantage it offers in off road situations. However, it wouldn't be hard to make a hybrid slider that was angled like the one pictured above, then weld in some 1/8 sheet (preferably dimpled or punched in a way that promotes traction and drainage). The flat portion would attach to the top of the tube, run straight towards the body of the vehicle, then angle sharply down and attach to the square tube underneath. It would probably look funny to do it across the entire top of the slider, but you could put a foot pad front and rear that passengers could step on to assist them into the vehicle.
I love my MetalTech sliders, but, those damn top tubes are extremely slippery and recently i've become a little worried that one of the kids is going to drop there foot down between the bars and get hurt. I have thought about adding grip tape, but that looks like crap. My other thoughts are a foot plate like I mentioned above, or ...... if there was a way you could notch the steel. Similar to the jimping you find on the back of some knives. I'm not sure what tool would do this consistently, and depending on your DOM wall thickness they would have to be fairly shallow. However, it would not only greatly increase your traction, it could look very nice as well.
@lcwizard sorry if this was more than you were wanting. Just thought I might share some ideas with you. Looking forward to seeing your 80 series product line. Also, thank you for taking the time to bring some new offerings to the market.
What would be the preferred look for an 80 slider. Flat or angled?View attachment 1209695 View attachment 1209696 View attachment 1209697
Decisions about the gear you put on your truck are always personnal because the "right" choice depends on how you are going to use it. This is like the argument between a 2.5 inch lift which requires no regearing vs. a 4 inch lift which provides more clearance for more aggressive wheeling vs. a 6 inch lift which is somewhat directed towards people who plan to rock climb. These are generalities but you get the drift.
If you are only going with a 2.5 inch lift then these sliders will actually be used as a step. If you are going with a taller lift then people are going to put their leading leg in the floorboard of the truck and hop/pull themselves up into the truck. This is another generality but it is also generally true. A 4 inch or higher lift is a long way up to "climb" into the truck by using the slider as a step and small children simply won't be able to reach it.
Another consideration is whether you want diamond plating on your sliders. When you are wheeling in anything wet, especially mud, it is going to really build up on your sliders. I have read some genuine complaints on this forum about the mud build-up being a considerable problem.
I chose Metal Tech sliders because their are large gaps between the tube and the portion of the slider that protects the rocker panel. As far as the slipperyness of the Metal Tech sliders.....they are like a greased pig when they are wet. I added grip tape on mine. It is like sandpaper but washes off really well....and it does look crappy. At some point I am likely to remove the tape and apply bed liner. You will want to do something if your sliders don't come with some type of texturing because they will be extremely slippery. Other may have better ideas and I will be watching to see what others suggest.
Obviously your choice but some things to think about when building for the 80 market!
I always liked that rear bumper design with the small riser to protect the rear quarter.
Your sliders look great, and my opinion favors the angled up version! I still have my first set of sliders I bought from Slee in like 2002. When the're done, I'm headed to Arizona.
Hate grip tape. It removes skin. Marine grip tape much better.
It absolutely does and I have lost skin a few times. I'll check out the Marine grip tape!
I too have lost skin. What's the source of this "marine grip tape"?
I like the angled sliders personally. Me and the family have no problems getting in or with stuck feet/paws with the Slee tube sliders. I'm 5'7" and my wife is 5'4" and it's never bothered either of us even with a 4" lift and 37s. My wife is one of those rare women who isn't high maintenance so I'm definitely not the majority here. Far too often I read posts about women complaining or outright refusing to get in due to sliders.
The sliders in the OP look good except for the diamond plate. Anything but diamond plate to fill in the space would look 100x better. And that rear bumper looks damn good by the way.
Even before I added sliders to my rig, I always liked the look of angled better over flat. Just looks "right" to me.
Love my 4+ bumper!
My vote goes to flat step sliders. My wife likes to complain and my daughter is a klutz.
:edit: I agree with VuickB6, not a fan of diamond plate. What would look really slick would be some plate with dimple holes to drain snow/water. A dimple die makes everything look cool. Probably adds about 15 horsepower too.
How much are these?
849.00 is retail. MUD price is 720.00 powdered 620.00 bare
It seems angled is the preferred. I've been building the angled since the mid 90's. I got a request for the flat last year from a local. I built them
and a couple people saw them and followed. I was unaware of the universal disdain for diamond plate as a step. I do have dimple dies all the way up to three inch. It doesn't do anything for traction but they look fancy. There's always the Vortec style coatings for traction and durability i suppose.
For me the primary function is rocker protection. Most people prefer the u bolt style attachment but I never liked the hardware hanging an inch off the frame rails. There are plenty of that style to choose from. We'll always use the weld on mount that the sliders bolt to for that reason plus I've never seen ours flex up enough to hit the rocker like many u-bolt styles do even when we set our clearance to rocker tighter. Our bolt on gives you some adjustment to tune the clearances from truck to truck. I've seen the frame to pinch weld distance vary right to left as much as 1/2".
You can always loosen all the body mounts and shift the body and tighten...but that's kind of a pain. The slotted holes in our mounts are quicker
They are more time consuming to install which is the trade off. The other weld on alternative without the ability to unbolt makes it tough to do paint and body work or move them to another truck when you wear out the first
