I'm reading the section of the FSM for the transfer case, and there's a step in there where I'm supposed to measure the oil clearance of the high and low speed output gears (oil clearance defined as the gear inside diameter minus the output shaft outside diameter). The limit is 0.0032 inches (standard is 0.0014 to 0.0032 inches).
Does this mean that I need both inside and outside micrometers accurate to 0.0001 inches? What are folks using to take these measurements?
