Powered Antenna Replacement (motor works)
Los Angeles
Hi all, I'm new here, just picked up a 1990 FJ62. Trying to fix a few items on the car. The antenna motor works, but the antenna shaft is broken and missing all of the extensions. Do they sell a replacement shaft?
The mast is available. I had the same problem and was able to replace mine. I’m not certain but I think I may have gotten it thru Coolcruisers.com. You may want to also check if you can get it directly from Toyota parts.
X2 I used a replacement shaft from another Toyota vehicle to replace the one in my 62.
I did it years ago, so I don't remember which model it was for, but I did find the # here on mud
In case you are still looking this should be the mast from Toyota: 86353-14332
