Power Window Motor
I doubt it burned out. More likely your window just has too much pressure to move up. IOW, there is so much resistance to moving the window that the motor reaches its threshold and shuts off. Take off the door panel and help the window up while holding the switch up. I bet it will start to move on its own.
Search for stuck/slow windows. Lots of posts on this. The window tracks get old and dirty over time and cause this.
If you remove the door panel and plastic sheet you will see the regulator arms. Even the window down can be removed. There is two 10 mm(sockets sizes) on each side of the glass to regulator arms. remove those bolts and the glass can be pulled all the way up. Take tape to hold the glass up in place.
I'll start with how to remove the door panel;
-pull the switch housing out by prying at the front of it with a flat screw driver. Disconnect the connector for the wires. Push the tab in the centre of the connector to pull.
- pop the arm rest pad off the door panel. Just pry it to pop off.
- unscrew the three phillps screws in the arm rest.
- remove the speaker.
- remove the one screw in the door handle lock area.
- take a flat screwdriver to pry the door panel off. Lift it off.
Remove the motor assembly.
- remove the four bolts on the rh side. One is an adjuster bolt, mark it.
- remove the two bolts on the lh side, the back on is an adjuster, mark it.
Fold the regulator and bring it out the hole in the lh side. First the electrical connector needs to be disconnected and the door control box moved out of the way.
Now remove the motor from the scissors. Three tight screws. Mark the posistion of the motor as the spring will move. Be careful it is spring loaded. But not too much.
Take the motor to a wreaking yard and compare with other toyota ones. Yesturday I found a toyota one from a 4runner that worked. Only the connector needed changing. Of course the scissors were different. But my scissors were fine.
The 4runner ones works fine. I will post a thread later with the differences.
When you get the door panel off and find the electrical connect that goes to the motor, try connecting the positive battery terminal to one side and the negative battery terminal to the other. This will tell you if you've lost your motor for sure. Switching the leads around will switch the motor direction (try both).
I lost a switch, and a couple months later, I lost the motor on the driver's side. It's worked great since I put in a new one.
So is the motor dead or was it just gunk in the channels? Or were the contacts just really corroded?
If dead, did you order a new motor or go with used? Where did you get it and what did it cost?
Just curious for future reference.
