Power Window - Goes Down / Not Up
VA
I have a 1997 and unable to get the Driver Side Rear Window back up. It will go DOWN via switch, but it is almost at bottom of window now so running out of testing room.
* Been looking for broken wiring - in progress (found some great posts.. thank you!)
* Replaced/Swapped with Passenger Side window button - Not the switch. Same.
While I keep on looking for the fix, I wanted to get the window closed. Any workarounds to get window closed until i find the culprit?
Pls help! Been a slow process but good learning journey.
Sounds like your motor is in need of replacement. How old are your window seals? They can slow or prevent the window from going up if they are old and dried out. You may be able to pop off the door panel and reach inside and push up on the window while hold the window switch. Another option is to squirt some Armor-All down between the window and the seal. That might give it enough lube to actually go up. I've had good luck just removing the motors, opening them up and cleaning them. Re-assemble and re-install. All four work like a charm now. The passenger side front blew the 30A fuse is what prompted me to rebuild them. Replaced my seals at the same time while I was in there.
It's your master window switch on driver's door. Get a SwitchDoctor switch for $25-$45 from amazon or wherever and swap out the master. I had the same issue, tore apart the rear door, swapped door window switches, motors, everything. Turned out to be master.
You can get it to go up by pulling the plug off the switch on rear door, pull a pair of wires direct from battery (+ and -) to use to run the motor. Check the wiring diagram in the FSM to see which terminals to touch and which ones to jump.
Toyota switches the ground side, not the hot side like most USA stuff.
Exactly what @BILT4ME said.
So we know where you are on the :banana: scale, are you doing this with the door panel off, or are you near your limits just getting the switchbank out of the handle?
If you’re talking a fully dead motor, you **can** shove the glass out of the rubber gasket & tin grabber/gutter & use a strip of duct tape to hold the glass up until you get things working.
By working I mean reliably getting the tin gutter that holds the plate of glass to run up & down.
IDK where you are on the tech scale, so just trying to keep this ‘digestable’.
When mine get a lot of that black powder build up in them the up portion starts to be less functional on the switch...i have to pull up harder on the up. To get the window to go up. If i clean them they work fine...i would clean first if you haven't. You will find a pencil erasor helps with the contact points. Since I there is less draw of amps to lower the Windows i noticed it never has the same issue. Also that side of the rocker has less buildup.
James - Thx! Window seals are old, but OK right now (was OKl) since it is summer. switch works going down.. not up. Will try to push up.
Hey Linus - Thank you. I have the door panel off! Motor not dead as it will go DOWN... now I am hit my limits of testing as window is all the way at bottom .
I seen a similar issue recently. Try pushing the switch down then up rapidly in as soon as it goes to the up position after a few times hold it in the up position. It sounds like the master switch assembly.
@BILT4ME @LINUS Update: Master Switch ordered from Amazon / SwitchDoctor and installed -- rear window is back up! One window Button sticks a bit (switch may need adjusting), and not 100% reliable on the Passenger Window but manageable. Thank you both and to everyone that provided info and insights. On to next project on the FJZ80.
