Power Window Blues
Anyone out there have this issue?: Front passenger window will go up and down when controlled through the driver's switch, but only up (not down) through the passenger's switch. I've tried using the rear passenger switch in it's place, same results, I then put the front in the rear's location, the rear window operates fine. Any ideas???
I have no ideas for you. But when you figure this out let us know I have had some real headaches with my power windows. My rear ones fell off of the tracks and my drivers one still does not work and the passenger front is slower the slow.
What's a 1981 Toyota Trekker??
Yeah, I've got an identical problem in my 92. I don't care too bad; it's fun to watch people go berserk trying to work the window :)
Subscribing in case anyone has found a solution.
The wiring for the non drivers doors are controlled by the wiring in the drivers door somehow. I ran into some issues I solved by cleaning but I think the electrical FSM (I think it has a different name) is required to trace that particular problem down. Once you have a schematic in front of you I think you can figure it out.
Something that Toyota/Winnabeggo put out prior to the original 4Runner. Sort of the "forerunner" to the 4runner.....
Not very many made...even less still around. Fairly rare...pretty cool.
