Or maybe hold out for a stock FJ40 PS setup, I did and it bolts up nicely to our 1961 FJ40...grind or torch the rivets off the old gearbox mounting bracket, bolt on new one with ps box, (uses same holes)...get a later model rag joint style steering column shaft and put it in your (now shortened from box end) steering column tube, fabricate what looks like a leaf spring bushing to position the box end of the column tube around the shaft, bolt on steering wheel (I had to get a later year "early style" wheel, different shaft/hole diameter, looks the same)...
Pump is up to you, I took out the PO's crappy V-8 and installed a 2F from an FJ60, the 40 pump and return lines bolt right up, even the cooling line fits in front of the radiator using the same mounting holes...looks just about stock and very little fabrication...tough part is finding the 40 PS system
