power steering...what type do I have?
I know there is a graeat deal of info in the faq and on this site about power steering mods. but I really don't know enough about the components that I have. I bought my 78 fj40 from a PO who intended to do a restoration and then lost interest. I have done a complete engine rebuild with a lot of help from this forum. Now I want to work on the power steering and need some advice about the components I have to work with. What type of components are these, what should I use what should I lose. Please be patient I will post a few more pics in a minute.
Thanks,
Patrick
Damn! landlord... that pump mounting bracketry is quite unique... how does the belt tension adjust????
I don't have a clue how the belt tension works. The bracket holes line up with the bolts for the water pump but I really can't figure the rest of it out. Any thoughts about a better bracket that I could use????
The bracket tensions with the alternator the same belt drives both and the other belt drives the airpump, cheers, Larry
I would consider a sag. pump and Dorry mounting....
The bracket tensions with the alternator the same belt drives both and the other belt drives the air pump, cheers, Larry
what if there is no air pump??
That is a 1979-1985 minitruck pump with it's original bracket. Remote reservoir is also minitruck.
The tensioner pulley is on a modified dealer installed Clardy York compressor bracket - wierd.
The PS gear looks to be minitruck as well.
Good luck
