Power steering troubles
Swanzey NH
74FJ40 with the mini-truck power steering box. Saginaw pump. On the road it works fine, on the trail when under a load it turns right with no problems. When I try and turn to the left it just doesn't have the same amount of power as when I turn right. What should I look for?
Thanks
Lane
Nothing that limits the movement or binds things up. Was afraid some-one would say new box. Are these things rebuildable?
They are rebuildable and should be cheap.. I mean under a 100. You can also go down to the junk yard and get yourself a good used one, if you have stock.
If your gearing a specially for offroading 3 - 4 turns clock to clock, then i immagine you will need to get it rebuild..
