To FIRST tighten the bolt on the banjo (1/16-1/8 turn or so -TIGHT) -that will tighten the fitting underneath (so it is now solidly tight in the pump) so that when the outer fitting is loosened, it comes loose instead of capturing the line between the inner and outer fitting and spinning-then damaging it as you continue to try to loosen. Have done it for many many years on Saginaw p/s pumps/lines and it worked on my 80.
Pump is out! Once the old pump came out, it didn't take much time to have the gear swapped over. The link to the write up helped, I don't know why I couldn't find it before. Now I'm just waiting 2 more days on a new pressure feed tube, which probably needed to be replaced anyway.
The part you may need help with is reinstalling the gear on the new pump. I used a strap wrench to hold the gear while a friend helped torque the nut. I think the torque spec is 54 ftlbs
The strap wrench is a good idea. I just tried using a towel and channel locks to torque it, but it's not to spec. I was thinking about going ahead with the install anyway, but now I'll probably go get one of these and test it out.
Counter Clock Wise. I did the same thing when I first got mine - the first O'riley hose developed a pin hole after 2 years. I was mad and thought I should get OEM but since it was still warranty, just swapped it out - the new one was much better - very nice quality
You may want to wait to put that hose on until after the pump is installed. Also, did you get the copper washers that go on the Union Bolt? The old style called for 2 washers. New style is a one piece washer 44327-30030
Take a look at the attached pic, it shows where those O-rings go.
Yes, the new pressure feed tube came with the old style copper washers, and they're installed already. I was worried because I never removed any o-rings when removing the old pump. The new one has the top o-ring installed already, and I'll do the side one right now. I'm going off the same FSM.
Also, the drive gear: What fluid was all over it? I plan to re-coat the gear before install, and I wiped it down to make removal easier. Was it coated in oil or ATF?
Perfect. That's what I wasn't sure about. I pre-filled the new pump with ATF. So is it okay to leave it dry if I don't have a spare quart of oil laying around, or should I make a trip to the store?
The easiest way to get air out of the PS system is to jack up the front end (both wheels off the ground) and with the engine off, slowly turn the steering wheel lock to lock several times, then add ATF until the level reaches the cold mark on the dipstick. Set the truck on the ground and start the engine, slowly turn the steering wheel lock to lock several times , shut the engine off and check the fluid level, repeat until fluid level is between cold and hot on the dipstick.
I followed the write-up by Romer and had everything done last night. Drove it to Houston this morning and it's ninja quiet. Well... As ninja quiet as a land cruiser can get.
FSM says the pressure hose fitting with 2 new crush washers torque specs are 56 N.m (575 kgf.cm, 42ft.lbs)
Thanks for the good write up.
Going to be doing mine here soon.
Actually that high pressure banjo fitting uses copper washers not crush washers as I mistakenly noted above. The torque specs are correct per FSM, 42 ft.lbs.
