power steering pump exact model
Denmark
So I need your help again guys. I have ordered this power steerling pump repair kit, but the dimentions are wrong. As you can see on the images the oil seal is too small. I guess this kit is the wrong one., can you help me to identify the correct one.
Toyota Landcruiser, eighties fj60 pump i belive, origin somewhere in far east, found it online in so details are unclear .. fit fine on my fj40 with 2f engine, but leaking…
can anyone see what exactly this model pump is, and the repair kit needed ?
Thank you..
chatgbt ( dont thrust it)
Confirmed Facts (No Guesswork)​
  1. Pump Style:
    • Toyota vane-type power steering pump with integral reservoir.
    • Not a later remote reservoir or splined shaft type.
  2. Shaft Dimensions:
    • Diameter: 18 mm
    • Length beyond housing: 34 mm
    • Keyed (parallel key), not splined
    • Key length: 15 mm
  3. Seal Bore / Front Seal Measurement:
    • Outer diameter of front oil seal bore ≈ 41.5 mm
    • This is consistent with an 18 mm shaft pump seal.
  4. Casting ID:
    • Only marking on body is 60020.
    • Consistent with early Toyota 44320-60020 family power steering pumps referenced in Toyota parts catalogs (though not always listed explicitly as a standalone kit for this casting).
  5. note: "Front shaft seal needed — journal diameter 23mm, housing bore ~41.5mm, vane type
These pics are from my Toyota issued microfiche set I picked up in the early '80's. They cover the FJ40 series, BJ40 and FJ55 for the US and Canadian markets for the period from 03/69 to 07/80. The set was issued Jan '81. The p/n 44320-60020 is shown for the 40 & 55 for the period 01/79 to 08/80. The kit for this pump shows p/n 04446-30010. I can't personally guarantee this info will work for you, but maybe it is a place to start.
Thank you @timmyisinthewell - but i'm pretty sure it from a early eighties FJ60 (somewhere in far east - Pakistan) anyway it looks different than the microfilm
the microfiche is showing a US spec pump mounts on left side of engine
you have a global spec pump mount on right side of engine
the seals should be the same but not certain
