power steering problem
i installed pwer steering set up on my 40, on my road test, i discovered a problem, when steer to the left steering wheel returns freely, when steer to the right, the steering wheel dont voluntarily turn back. another question is, is there a computation for installing pwer steering setup. thanks for any input, pics will follow
You're going to have to give more info than that. What system?
Try disconnecting your steering dampener if you put one on. Get that wrong and you could have this problem, but there's other reasons too.
You must have done something wrong but without knowing what you did how can anyone help you?
You probably still have some air in the system. Check the fluid for foam and check the level when the pump is running and after it is shut off. If the fluid level rises when shut off, there still is a bubble somewhere. Sometimes parking facing up or down hill can help get rid of a bubble.
Bleed the air out. Put the truck front up on a sturdy jack. Put on parkingbrake and put truck in neutral. Start engine, turn steering lock to lock several times slowly. That should get the air out. If necessary stop between turns and check fluid.
