Is everyone still using the metal cooler line on the return side? I have the GM pump with a hard line (metal) to the Toyota box. From the Toyota box I have a flared hard line to a rubber line to the flared hard line cooler, then from the other end of the flared cooler line a rubber line then to a flared hardline back into the GM pump. After running the McGrew this weekend I lost most of my fluid and found it was leaking from on of the rubber lines. I tightened the hose clamp but it still leaks. I can't see any damage to the hose and it looked like it was coming out the end of the hose past the hose clamp. I would like to run a high pressure line from the box to the pump to bypass the rubber hoses and metal flares on the cooler line if possible. I am guessing there is too much pressure on the rubber lines and it is pushing fluid past them, although this is the low pressure side.
Any ideas?
Any ideas?
