Power Steering Line Leak
While doing the valley plate reseal on my truck I noticed what appears to be a leaking high pressure power steering line. Has anyone experienced this before? Looks like Toyota only sells the whole line for $500+.
Ditto on my 2013. I waited until I was topping off the fluid monthly
@tbisaacs @linuxgod do you recall if there were any access issues? The FSM suggests a flare nut crowfoot is required for the rack side nut.
I don’t know, Slee replaced mine while I was in their shop, so I’ve no clue how easy or hard it was
I ended up having the dealer install. Bought the OEM part during an online parts sale. Without a lift getting in there is a real challenge. Not impossible but real difficult to access. Dealers charges a couple hours to knock out.
Tackled the job this weekend. The rack connection can be accessed from above the frame rail using a flare crowfoot and wobble extension. For the two bolts holding the support brackets, it is easier to first remove the lines from the brackets, then remove the brackets from the steering rack.
It took a substantial amount of bleeding (front wheels off the ground, engine off, turning the wheel lock to lock) to remove all the air from the system. Have a helper watch for bubbles in the reservoir as you turn the wheel.
Parts used:
Part NumberQty
high pressure line44410-607101
banjo bolt crush washer44327-300401
sensor gasket90301-110211
return line clamps90466-160022
