Power steering issue
IL
I am having an issue with my power steering some times it feels like it's gone. Sometimes it's really hard to turn right when at a stop. You can some times feel a pop when you're turning right and it doesn't feel like the power steering is working then all the sudden it feels fine. I know there is a slight leak. I did have to had a decent a mount of fluid and ever since the the levels been fine. I did use the correct atf. Any ideas what the issue is? Could there be air in the system?
i had the same issue, check to make sure your main crank bolt is tightened to spec!! ...like over 300 ft lbs!!!!!...
After I did that and adjusted the stops on the steering knuckle, I have not had the issue. Knock on wood!
I'll have to look into that!
The crank bolt being lose can actually have an impact in the power steering not working sometimes?
yes, because the oil pump AND the power steering pump are driven off the main drive...But then again, i am only a 2.5 banana diyer! hopefully someone with more experience can chime in! @ChiTown?
i had a friend leaking so much from the oil pump seal he was loosing pressure as well. After he sealed up the oil pump seal the issues seemed to die down.
That's from the front? I don't have any leaks from the front except the power steering hose. My oil level has been perfect since I fixed the vc gasket. I have been at the sand dunes in mi and went through deeper water than I should have. That's when I noticed the oil sensor showing idling being a little lower than usual so I'm not sure if it has anything to do with the power steering issue. Idling is a little rough now too but I think that's just from the water and possibly the distributor cap so I am not worried about that.
Right now is just like to fix the power steering. It's weird. It all started after the fluid level was low and topping it off. Maybe it is the fluid?
The drive gear on the crank is held by the pressure of the crank pulley and the torque of the crank bolt. If the bolt is not torqued down it will slip under load.
How much free play do you feel in the wheel when going straight? Do you feel the "pop" in the steering wheel?
Have you checked your steering arm nuts and your tie rods? Maybe there is binding going on that is causing the stopping.
Also, fluid should be ONLY Dexron III, or ONLY hydraulic oil, or ONLY Power steering fluid. If you don't know what was in there and poured something else in on top of it, the two oils may not like each other.
Crap I think I put a Toyota Atf VI if I remember right. Maybe it's just the fluid?
I actually doubt it's the fluid. I'm thinking mechanical. It could also be trunnion bearings or steering components. Have you ever rebuilt the front axle?
I've only had it for a couple of months. Don't think the front axle has been touched before.
I would start with a mechanical inspection at each wheel.
Wheel bearings
trunnion bearings
Steering arm attachment
tie rod ends
drag link ends
steering damper
steering gear
lateral control rod
Place the front axle on jack stands, then do the 6:00/12:00 lift, movement thing to check wheel bearings and also trunnion bearings.
Grab the wheel at 3:00 and 9:00 to see if you get steering arm movement, tie rod end movement, or problems with the steering damper.
Turn the wheels lock to lock by pushing on the tire (with the key on - steering wheel unlocked) and see how hard it is and if any "grinding", rough movement, or "bumpiness" is felt. Do this on each side.
Also inspect the PS pump for leaks.
There is also a screen in the BOTTOM of the reservoir that MAY be clogged. You must remove the reservoir, turn it upside down, and flush the reservoir with fluid and probably brake cleaner. This is usually kind of messy, so do it last. It could be the pump is starving for fluid because the screen is blinded.
Good Luck!
Wheel bearings
trunnion bearings
tie rod ends
drag link ends
steering damper
steering gear
lateral control rod
Good Luck!
Thanks. I do know one of the hoses on the ps pump leaks.
