Power Steering Goo
SLC, UT
On the way into work this morning, I noticed a whining coming from the PS Pump (I thought time for some more fluid), and buy the time I got to work the power steering was intermittent. It was still dark so I could not see were the leak was coming from but I noticed a considerable puddle on the street. When I pulled the cap to add more fluid (engine still running) I had to jump away, as it was gushing out of the top of the reservoir and it was very foamy and the color of milk chocolate. It sounds like I have some work to do this week end, but first I have to diagnose the problem. If I had a leak in the PS pump O ring would the fluid still get foamy and gurgled out of the top of the reservoir? Is it common for the PS lines to fail? Just want to get a heads up on what to look for? Any help or suggestions would be great!
The PS reservior should be checked when the engine is off. When you have good lighting, look for the leak; might have to wash off the area then watch where it is leaking from. Do not run it dry; add more fluid until it is fixed. Not common IME for the high pressure hose to fail with one caveat; has the pump or hose every been worked on before?? Mine developed a significant leak once, but it was due to the mechanic reusing the non-reusable banjo crush washer for the high pressure hose when he put it back together.
When low enough to suck air, the fluid can foam, expanding it. Fix the leak, fill it up, should fix it.
But when it suck air, it means are the reservoir complete empty .. I saw some very foamy fluids when it's old and hot due to efford in the PS pump ..
I got if fixed over the weekend. Turns out the low pressure rubber hose between the cooler and the gear was warn and leaking. I replaced it with new hose and it is fine. I was surprised how brittle the old hose was, I think it is a good idea for everyone to check and maybe keep some spare hose on hand in-case it happened on the trail.
