Power Steering Fluid Flush Question
Knoxville, TN
My power steering pump had been groaning when the fluid gets hot, so I decided to replace the fluid yesterday. I read some threads and decided that the actual fluid I use doesn't make a huge difference (it's just hydraulic fluid, right?) so I bought a gallon of Valvoline power steering fluid (not ATF). I drained/flushed the old stuff out (black, nasty and smelled very burnt), topped it off with the new fluid and flushed it through and then refilled again with the new fluid. I probably removed/flushed a half gallon of fluid through the system.
Now I have beautiful new fluid, and I would say that the steering feels smoother, but the "groaning" when hot is no better (and maybe slightly worse). Is the power steering fluid a bad idea? Should I switch to the Mobil hydraulic fluid? Go back and use ATF? Is my pump toast?
I would go back to ATF and bleed the system of air. I've used the process given here on MUD a couple of times with good success. While the PS system is cold I jack up the front and put the truck on stands. I then cycle the steering wheel from stop to stop 8-10 times and check the fluid level, add as needed. I go through this process three or four time or as needed to get all the air out of the system. I take the truck off the stands, start it up and let the system warm up some. Then I cycle the steering wheel from stop to stop and check for proper operation, smoothness, leaks and groans. This has worked for me a number of times. I rebuilt my PS pump about a year ago because it was leaking. The vanes and internal parts looked and worked just fine, it was the seals that needed replacing.
Your process is pretty much what I did yesterday. I disconnected the line that returns the fluid to the reservoir and attached a piece of clear tubing to it. I snaked the tubing down by the front axle and ran it into a milk jug. I had the front tires up in the air on jack stands so I could turn them easily. I was able to remove most of the old fluid by simply turning the wheels back and forth a few times (engine off). I then topped it off with new fluid and did the same thing. I then topped it off again and started up the thing and let the pump push the fluid out. In all, I probably removed/flushed a half a gallon of fluid.
I topped it off, got rid of the air bubbles, etc. and drive it around yesterday afternoon (about 1 mile mostly to make sure I didn't screw something up). The pump was blissfully silent and I would swear my steering was smoother.
This morning's 20 mile commute to work greeted me with the pump groaning. Maybe Toyota was serious when they said to use ATF. ;)
If Toyota recommends it, why use anything different? Flush the system and refill with ATF. Id be willing to bet that will make a difference!
Been running Mobile DTE for a few years in everything that asked for PS fluid with excellent results along with several others in sunny (HOT) AZ.
Yeah, I thought about this also. I guess it's safe to say that you don't have to use ATF? That was my logic (FWIW) in using the power steering fluid.
I need to see if there is anyone local who sells the Mobil stuff...
Groaning can be caused by several things, it's cavitation, so can be from air getting in, or trapped in, or made in the pump, etc. Old, nasty fluid is much more prone to cavitation, so the first step is fresh fluid, depending on the root cause, may or may not fix it.
ATF will work, but the steering is a fully hydraulic system, so doesn't need the additional additives that it has to deal with the clutches, etc. In our experience P/S or hydraulic fluid perform better, take more abuse before cavitating.
Most often cavitation is caused by a leak and/or restriction between the reservoir and the pump. Check for a leak in the suction hose/fittings feeding the pump. The most common restriction is the filter screen in the reservoir, if the fluid isn't changed, allowed to become nasty, can clog it up. Given time/use, new fluid can sometimes clean it up, most often it needs to be removed and cleaned or the reservoir replaced.
A good guideline for cleaning filter:
Thanks for the info, Kevin. I have no leaks in the system and the hose from the reservoir to the pump is in good shape/not kinked, etc. After seeing the condition of the fluid I removed, I suspect my filter screen in the reservoir is in rough shape.
That video is awesome. I might give that a try! Thanks!!
UPDATE: I got home from Monday from work with the pump still groaning somewhat. I checked the fluid level after it cooled down and it was a bit low so I topped it off. I drive in to work the next morning and the pump was silent. Even cranking the wheel to park produced no noises at all. I was cautiously optimistic, but I figured the real test would be the drive home. Cranking the wheel almost to full lock to pull into the garage after 20 miles of driving home always made the pump groan pretty good. Silent. I checked the fluid level last night and it was right where it is supposed to be...
So...I think I simply had some air still in the system and it took 40-50 miles of driving to work itself out. It seems to be fine now. In fact, I'm a little surprised at how quiet it is - my old fluid really needed to be replaced...
IronCladLou, I think you're right.... air in the system. Silence is golden...
If air is well entrapped, foamed into the fluid, can take a couple of drive cycles to remove. And/or, the screen was somewhat varnish restricted, making the air removal more difficult, the new fluid cleaned it up? At any rate, good result, now change the fluid every couple of years and good to go!
