Power Steering Box
Portland, OR
Does anyone have a source for a RHD power steering box for a '92 fj75?
Thanks in advance.
The truck does not have power steering.
I'm pretty sure they can be rebuilt regardless of whether they are power or standard type.
You need to find a kit. Is it an Australian model, there was few sold here but not many?
It's a fire truck that was imported from Japan.
To confirm, it has manual steering and I'm trying to convert to power steering.
You should have said what you were doing in the 1st post. Most of the components are the same as other 7* series,only the pump is different. Is this Crusher's old farm truck?
Plenty come up on ebay.com.au with the pump and hard lines also Toyota should still have new in stock. What motor is in your truck because 2h and 1hz have different pumps.
3F gas.
Well you can source everything else stateside except the steering box well that will make it cheaper to send over
Thanks for this. Let me look around over there and see what I can find.
Thanks for this. I'm going to need to save up for a month but will circle back. I do appreciate your help.
