Power Only While Key Is Turned To Start?
LFD2037
TEXAS LEXUS!
Wax., TEXAS
I want to hook up the 'starter isolator' on my Blue Sea ACR 7610. What wire/fuse in the underhood fuse box has power ONLY when the key is turned to START (not run)? Thank you in advance for blessing me w/the info I seek. :cookie:
Well, not in the fuse box... but the wire going to the solenoid on the starter would only be active during start... assuming I understand what you are asking.
cheers,
george.
Pulled from another thread ....
h3-and-rs-in-harness-spreadsheet-jpg.370311
cheers,
george.
Where does the wire from the solenoid go? To the ignitiIf so, it goes from ign. switch to? Tapping onto the starter is a PITA so I was wanting to tap into it under the hood. I need it so the ACR 'disconnects' from the 2nd battery while the starter is running.
The wiring chart above just confuses me. I have no idea where any of that is. Thanks anyways!
I'm talking the small wire to the solenoid, not the big BAT+ cable. The starter is under hood which is your request :)
Doesn't the ACR already disconnect the 2nd battery while starting since the main battery voltage will be rather low during the starting/cranking cycle?
cheers,
george.
I was thinking you wanted wiring from the ignition switch. The diagram I posted is from the wiring harness coming out of the ignition switch under the steering column. But after re-reading your post it looks like George is telling you what you need to know.
cheers,
george.
The starter is moreso under the truck than the hood & a royal PITA to get to. Do you know where the small wire, that's on the solenoid, go to? The ACR does disconnect when main battery gets under 13.4V so in actuality I probably don't need to connect the SI but I'd like to anyways.
The ACR will do just fine. No way will the main battery sit at 13.4V or higher with a few hundred amps being sucked from it by the starter.
Save yourself the work and go have a nice cold beer instead...
The EWD should show where the solenoid wire gets routed.
cheers,
george.
cheers,
george.
I've read your website multiple times & have read may of your electrical posts. You say don't bother, I won't bother! Thanks. Btw, thanks for your site, too. Very helpful.
