Power LOSS
SO I have a 1981 BJ42 with the 3B, Its had an electrical regulation issue, now fixed (Thanks). Now it has developed a not wanting to run issue. To get it started I prime the whole fuel system, and it fires up first try. It will run fine and i'll stick it in a high idle. In about 10-15 min you can hear she starts missing, and it gets progressively worse untill it sounds really bogged down. At this point you can tap the gas and it'll pick back up again then drop down to said idle, and that will work for a couple of minutes until you can floor the peddle and the engine won't respond over previous mentioned bogged down idle. Then it will stall. I've drained the entire fuel tank and replaced with good fuel. there is never any black smoke so I don't think its an air issue. I've drained the water separator, several times, and only a bit of fluid come out each time, it looks more like diesel than water so i guess thats okay. Due to the time it takes for the symtoms to appear I dread it is an compression issue. Please let me know what you think. Thanks
If you have to reprime the fuel system to get your engine started again - Then I suspect you have a pinhole leak somewhere in the suction (below atmospheric pressure) part of your fuel lines. This will cause diesel from your fuel line to drain back into your tank (and be replaced by air) while your vehicle is lying idle. No diesel will escape to show you where the leak is - unless you pressurise your fuel tank (or perhaps you could try filling your fuel tank right to the top and parking on a downhill slope?)
Then when you start it again (next morning or whatever), it starts and runs fine until that slug of air reaches the injector pump - At which point she starts stumbling and eventually dies.
If this is what you're experiencing ----- read this thread about my similar experience and how I fixed it:....
https://forum.ih8mud.com/diesel-tec...5-solved-tricky-air-getting-fuel-problem.html
:cheers:
PS. - I'll post the link in a minute by editing this post (as soon as I've found it.)
just because there's no black smoke doesn't mean that there may not be a fuel leak. Sounds like a very slow/small air leak in your fuel system. Double triple and quadruple check all obvious spots. If you've added an aftermarket fuel filter these are notorious for leaking. I've had bad lines, bad fuel primer pumps and bad aftermarket filters. Keep digging and good luck. A lot of patience will do you well here.
Thanks for the Replys,
The first time it quit on me I put in a new fuel filter, so that shouldn't be the issue. there is only one filter. I First suspected that the reason I have to reprime the system is that I always run it untill it stalls again, but I guess that could also apply to a hole somewhere in the fuel line?? I like that idea, new fuel lines are cheep. anyone have a source on those?
Hey lostmarbles, Thanks for the post, what psi were you running when you stuck a motor cycle grip to your tank?
probably a better idea to find the leak before I start ripping of things that don't need to be ripped. hopefully this weekend it will stop raining.
I didn't change the pressure on my compressed air unit so it was probably still set around 60psi (which is what I use for spraypainting).
But that pressure is really unimportant because nowhere near that much would have been applied to the tank. (Thank heavens - Because it probably would have exploded before it reached 60 psi.) The motorcycle handgrip was simply held against the "filler entry" by hand-pressure so I doubt the tank would have been subjected to even 20psi (but it is hard to tell exactly what pressure it would have reached).
:cheers:
PS. Yes. I agree that you should actually "find a leak first" rather than replacing things based on suspicion.
And I'm glad to hear I'm not the only one who's being prevented from working on my cruiser because of rain:D
lostmarbles, may I call you "Sherlock" from now on :D
Reminds me that I have to get one of these great wiring pliers you're using ;)
the only time that I get problems with my injection in my 2H was the plunger at primer .. tires can't get enought fuel from the tank .. and instead of fuel get air ..
So with a diesel 5 gal tank .. over my rad I conect it direct to my fuel filter and start my engine .. it flow by gravity and the engine run without problems ..
Other test was when the engine was running rough open the filter bleed port and note that where no much fuel pressure .. and at segs open start the air bubles ..
