power draw while car is off?
Pacific Northwest
So I changed my ground clamp tonight and noticed it sparked when touching to the negative post--this indicates there is something drawing power--correct? Does the cruiser do this stock or do I need to start hunting? By the way nothing was turned on.
After market(everything is fused)
Have a amp in the back with a fused 2/0 power wire running to the back cargo
Lightforce 240's using a relay wired to a lighted switch (turned off)
Fogs with a relay with my low beams as a trigger
Horn using a relay with factory horn as a trigger
Head unit with fused power wire
After market pusher fan with relay triggered by lighted switch
maybe its the snorkel:rolleyes:
Small spark is normal, there are several power draws, ECU memory, radio memory, clock, Alarm etc
Factory continous draw is something liek 20-30 milliamps,
There is an inrush when it is first hooked up.
https://forum.ih8mud.com/showthread.php?t=94932
