I need a favor if anyone can measure the battery drain on there 80.
With the doors shut dome light switches turned off and key out of the ignition.
Disconnect negative battery cable and any wires.
Connect Multi Meter set to DC amps(I am using the 200m setting) in between negative terminal and ground cable.
Measures 23.10 milli amps
Disconnect Main Positive cable leave fusible link connected.
Measures 20.3 mlli amps
Pull ECU B Fuse (fuse box under steering wheel)
Measures 17.3 milli amps
Pull Dome light fuse
Measures 5.1 milli amps
Thank you
On some 80's the door switches are not totally turning off the dome lights.
Lights dont light up but the is a larger draw. Usually it is the rubber wearing thin. You can test by pushing the button in by hand and see if you get a different draw reading.
Thank you
