power brake conversion, no pressure???
Have recently upgraded to a power brake set up...disc/drum. I have no pressure. I have 17 inches of vacuum which is what the manufacturer calls for, but the pedal has to be pushed so hard to stop it is dangerous. I have to push so hard the threaded rod the connects the pedal to the master cylinder bent like a potato chip.
Any ideas on what might be going on. I have a proportioning valve that came with the kit and hooked it up as I was told.....not sure what the problem is, but I had better brakes when they were manual. Brakes have been bled and bled, and bled......there's not much blood left to bleed......
Any help would be appreciated. 74 FJ 40
did the pedal travel easy when bleeding? could be binding somewhere, or your out of travel on the pushrod, adjust maybe
Both replies right on the money. Your master needs to "breathe in" before it "breathes out". If you bench bled the master, try shortening the pushrod and letting the master back off all the way.
Ed
