I just installed a new mast but now the antenna works when it wants to. Removed antenna assy checked all grounds reinstalled and the mast worked for two days and has quit again. What is the deal
Sooo, it acts oddly and unlike the way you expected it to?
I'm asking because in the 97 LC there is an ECU that comes in between the radio on the mast assembly. I read through the various FAQ posts on this before I fixed mine, obviously giving more attention to the 97. These were revised to use the LX system, which allowed manual setting of mast height, then the system would remember it when the truck was turned off.
I think that 96 and earlier 80s used a different ECU. Perhaps there has been a failure or wiring problem that's affected the circuit. The pre-97 LC have a different switch. What does it do? IIRC, the switch just provides mast retraction? Turning on the radio causes the mast to extend?
I can turn the radio off and i hear a click under the dash,the same click i hear when i touck the antenna up or down buttons. I also hear the same click when i turn the radio on or off and turn the key switch on or off nothing changes! It is just a pet peaf.
