Power Antenna Removal
I am in the process of replacing the stock radio- the light is out and the left channel sometimes works. Additionally, I am going to replace the power antenna, the gears are stripped and mast is bent. I am just going to replace it with a whip antenna. Question is, how is the best way to access it? Do I need to go in through the fender or can all the bolts be access through the small access hole in the engine bay? I was going to cut the antenna line and tie a line to it and snake the new antenna line back through.
you can do it from the small hole in the engine bay but it takes time. a ratcheting wrench 10mm i think is what it took for me.
The antenna drive is probably OK. What's busted is the mast. The mast is pretty easy to replace and pretty cheap vs the antenna drive assembly. Search is your friend here. It basically involves running the full mast out, taking it off, and retracting the new into the drive.
Having replaced the entire unit before knowing this, I can tell you even if you're wise enough to tie a fish line on before you pull the old coax out, it is a royal :censor: PITA to get the new coax back through the 90 degree bend into a small hole way, way back and up at the top of the inside of the fender and back under the dash.
I have an antenna cable and drum that I bought and didn't end up needing (just replaced the mast).
Normally $26.95 plus shipping. I'll ship it to you for $20 if you want it.
Green Truck- since I have owned the truck the mast only goes up half way with out assistance before making a grinding noise, though before it got bent it went down just fine!:(
If its just the mast I am all for replacing it...you think it could be that simple?
So I did some research and it looks like these replacement masts are about $50 give or take. The whip antenna I got from Auto Zone was 9.99. That being said, being as I am not a purist, is it possible to re-route the antenna wire by taking it across the front of and through the firewall instead of having to fish it back through the original route?
You would have to drill a new hole for it in the firewall. The reason they call it a firewall is that it's intended to limit the spread of fire into the passenger compartment in even of an accident, as well as to help exclude CO2 from entry also.
Drilling a new hole defeats the purpose of that. Plus you'd have to find some clear area without something on the back side to punch through.
I suspect you just have a mast problem, but someone else will have to verify. When we bought ours, the mast was broken clear off, and I didn't understand it was replaceable, so I have no experience with how mast failures occur or partial failures. I have experienced spending more than $300 to replace the whole thing (OUCH!).
If you didn't check with one of the friendly MUD vendors on price, you might find it's less than $50. And there is the guy who offered you a deal...
Posting this on a couple threads.
The motor can be fully removed without removing the antenna cable to the radio by following the steps you'll find and bringing the motor through the hole into the engine bay. However at that point if you remove the screw just below where the antenna shafts meets the motor housing the shafts along with the attached cable can be separated and left in the engine bay. I was able to clean the brushes, not lose all the small parts and get everything back together on a bench which would of been about impossible
Do you still have the mast and cable? If so I will take it! Thanks! DLPDLP
And I think my mast is fine and that I just have a broken cable so that is what I really need but will take both for $20 for sure.
I bent mine bushwacking.. Sort of, maybe on purpose.:cool: I'm patching the hole and installing a hidden antenna. On the windshield.
