Powdercoating ?
Medford, Oregon
I posted by mistake in chat :doh: Anyway, did some body work on a small metal item using the lead technique adn was wondering if powdercoat will stick to the lead/solder?
I believe PC will stick to anything metal.
GL
Ed
Powder Coat will stick to anything. The only limitations to Powder Coating is the heat tollerance of the item being coated. This is because it has to be baked. Obvsouly you cant PC somthing that is going to melt in the oven.
Powdercoat will stick to most anything, but there are limits. In order for the powder to have good adhesion, the surface needs to be clean and have some roughness for the powder to adhere to. Just let your powdercoater know what metals are involved and they should be able to give you a good coating.
My customers rings on his beadlocks are flaking, why? Cause they sprayed it onto a smooth surface, should of been blasted or sanded at the very least.
Very sensitive to rust and will pop off during baking.
At what temperature does lead melt?
Pure lead melts at over 600 F, so powdercoating temperatire isn't a problem. Sorry about your customer's rig. It sounds like a bad powdercoater. Preparation and cleaning are just as important in good powdercoating as in painting. Always go the extra step, because powder is REALLY that much harder to get off than paint.
