What leak? Maybe I’m too old.In the market for a 200 and came across this lx570. Does anyone know what this wet area might be from? Any concerns? Thanks.
Same here.What leak? Maybe I’m too old.
Maybe try circling it on the image? I don’t see any leaks.Bottom right if you zoom in some there is some wetness I think. Not sure what it would be from.
I spy with my little eye some wetness on the driver side rear lower control arm mount?!?
What more do you know about the radiator leak?Rubber pad jack theory makes sense! Thanks
Thanks for clarifying location TLC2013.
As far as cam tower and timing cover, it seems like these are probably pretty likely to happen so if not an issue now probably will be in future. So less concerned with these types of leaks because even if I buy one without it , it likely will happen during my ownership. That’s my thinking on it right now.
I’m separate issue I am somewhat concerned about possible damage from a radiator leak prior owner had but it seems like that’s a gamble as far as knowing extent of damage.
10Was oil changed every 5k or 10?
I’m not saying that’s a deal breaker if the price is amazing, but many of these had the oil changed every 5k which is much better for the piston rings as the engine accrues miles.
