Porter Cable mod# 7424...
...works very well. Medium cut polish/leveler followed by a fine cut.
PC 7424
before
after
Holy cow, is that my beloved Moonglow pearl? Mine could use some TLC too. Thanks for the info dude.
If you run the Porter Cable 7424 DA buffer, try these pads The Edge 2000 6 Inch DA Pads: The Edge 2000 6 Inch DuraFoam Pads will change the way you think about buffing pads..
You have to buy the adapter ($17.99), but the pads stay centered and I have detailed about 20 vehicles with one of the pads and it is still holding up well. The pads are a bit expensive, but you get two sides, so divide the cost in half. I use the orange light cutting pad for pretty much everything. I end up flipping the pad about halfway through a vehicle and use this DP Polishing Pad Rejuvenator was created to provide detailers with a fast and effective way to clean pads without soapy residue or foamy degreasers. to clean it up.
After 6 years of using my Porter Cable 7424 and ~2 years of using the Edge pads, I could not be happier.
Riley
So, I can use these to remove the haneous pin striping on the body w/o damaging the clear coat?
It depends on the depth of the scratch. If you can catch your fingernail on it, it is pretty much there until you paint again. You can, although, soften and hide the scratches with polish and wax.
Riley
