I did Eastwood several years ago on my frame - FAIL, flaked off
This past year I have used Rust Bullet. Look in my build thread below in my sig. Will it work? Time will tell. I used a 12,000 RPM grinder and brush this time instead of my hand drill to get down to metal. Then used RB's Metal Blaster to convert the rust (worked), then applied RB silver (2 coats) and covered it with RB Shell Black. Frame looks great
I have taken my doors off and am in the process of "renewing" them. I clean out the bottom sealants, clean the metal, brush the rust, then applied RB. Much better protection than the OEM stuff in the doors. So all my doors will have 6 inches or so up the wall of RB on the bottom seal. Water runs right out the holes - which you much ensure are still open
Now my front fenders were black, so I have painted them with Shell Black, so that is different from a regular restore. But on the inside quarters, I will use RB after the rust is cut out and new metal put in
dougbert
