I POR15'd my FJ40 frame, axles, driveshafts, steering parts, engine(POR engine paints), transmission housing, etc; I aslo used Zerorust(spraycans) and had some parts powder coated. The POR15 isn't nearly as tough as it's advertised to be, but it has held up well on parts that had been sandblasted or very thoroughly cleaned. It didn't work so well on brand new metal and doesn't work period on aluminum, peels right off. The parts I've used Zerorust on are also holding up very well; I like the Zerorust finish (flat not shiny) on frame and drivetrain components. I recently did the frame on a F250 work truck with Zerorust, it doesn't seem to chip as easy, but it seemed more viscous than POR15, making the application(using a brush) a PITA(reducing it a little would have been a good idea). All that said, I like powder coated parts way more than the other two coatings, much, much stronger, better looking, the only downside it's friggin pricey.
If you're going to have the frame galvanized I'd just use an epoxy primer, like PPG DP50LF(I think that's what PPG calls the stuff), it dries to a nice flat black finish.
