popping birfield advice
Simon
Buy a used birfield, have Travis take it apart & inspect it, complete his treatment and ask him carefully to assemble the birfield. On the 5 I had him do, all the inner spider gear splines were burred. Looks like he use a drift to assemble the birfs, which burred the leading spline edge. It was a quick fix to file the splines clean again to insert the inner axle.
To preserve your "Smurfield", you need to asseble the inner axle without the inner Cir-Clip. You need to place a small weld on the axle spline that engages the differential spider gears. This can be done on the axle shaft that doesn't engage the front electric locker. The weld keeps the axle from traveling into the differential.
The reason for not installing the Cir-Clip is that the inner axle breaks at the spline. With the Cir-Clip installed the broken axle stub is very difficult to remove from the birfield inner race / cage, since the birfield can be reused. The main function of the Cir-Clip is to keep the inner axle shaft from riding into the differential side gears, etc.
You can install the clip without changing the characteristics of the new improved birfield. Grease the smurfed 80 birf [like you would a new bearing], install into axle / maybe a new inner axle seal, and relax with a #6, since you are not going to break that birfield again!
Joe
[quote author=Warthog link=board=2;threadid=8856;start=msg77388#msg77388 date=1071773116]
The "Longfields" & "Profields" are brand new birfields, which are a little thicker in the bell channel and then treated to reduce the hardness / brittleness of the OEM specifications.
[/quote]
I just want to clarify, that the aftermarket 80 series birfields are the same size as OEM, not larger, or with an extra ring.
The mini truck/40/60/62/etc. birfields are the ones that are different than OEM.
80 series are only treated different. Also, when I talked to Newfield a while ago, they said they were *making* theirs, but to the OEM size, and heat treating them so they were less brittle (ie. softer)
It's a bit confusing.... I was confused too when I was shopping for a birf. That's why I'm trying to make sure everyone is clear on the differences.
Joe,
thanks for the tips. I will mention the burrs to travis. I am no welder so I may use the c clip and suffer the consequences if I snap an axle shaft.
To potentially add to the confusion about differences, afaik Longfield and Smurfield do not have access to 80 birfs, so they use your used core or any new one you care to supply them. The only sources for supply of a new 80 abs birfield I know are manafre, OEM, newfield and, coming soon, Slee.
Simon
Currently, all the treated birfields for any 80 is YOUR core / birfield. If Christo secures the birfs from the OEM supplier, then those could be treated & would be new.
Chris
Thanks for mentioning that tidbit. I forgot CV made the newfields the same as the other birfs.
Joe
