points don't fit!!??
Tucson AZ
I was doing some tuning on my 71 FJ40 and noticed the dwell was way off, so I adjusted the point's gap to 0.18. Started it up but it was only firing on 3 cylinders. Points were pretty beat up looking and I had a couple newer looking sets on a box from the PO. Decided to swap out one of those then head down to the store for parts.
But when I pulled off the old set, there was only the adjustment screw holding it, the entire center pivot post for the spring remained in the distributor! I compared a new set of points with the set I took out, and they were close, but the new one's don't fit, just a tad smaller where it reaches around the lobes.
The dist looks stock, but might have been swapped at some point. What's the best way to check and find the correct points for it?
Another weekend of wheeling lost :crybaby:
i don't have an answer, but consider getting the pertonix electronic dist. or upgrading to a newer year that uses electronic..
to look at it in a common sence way, it probably wouldn't have been taken out and changed to another points type dist. it would have been swapped to an electronic type, maybe they gave you the wrong part? i dunno but goood luck
It might not be a stock distributor. My mallory has a single screw that holds the points in place, and it's the same one used to adjust them. I didn't realize it wasn't stock when I bought mine until I bought a cap and rotor and they were way different. Even the P/O said it was a stock distributor in the ad when I bought it. A 79 with points?? sure.
You greatly underestimate the stupidity of the oft-lamented "previous owner".
That said, pictures would help a great deal. Especially of the distributor itself. Somewhere, there's a post with details on all the various iterations of cruiser distributors. That may help you self-diagnose.
bandy rooster said:
...consider getting the pertonix electronic dist. or upgrading to a newer year that uses electronic..
That's one of my thoughts, but if the points don't fit, I want to make sure I get the right electronic model.
The tech links are useful, but the "small" distributor description didn't help much.
Here's a few shots of my dilemma, hopefully they will make sense to someone.
I'm no mechinacal guy. If I have the stock distribator on my 1977 fj40 then I don't have points correct?
That distributor needs to be cleanded up. Then spend $130 for the best solution for ponts distributor, a pertronix setup with a flamethrower coil and the assurance you never have to set points again. Do it now and you will never be sorry you did. Plus you get rid of the ballast resistor and your cruiser will run like a top, if everything else is working.
Azlar; pretty sur this is not a Delco, like I have in my '79. MAF sold these a number of years ago. We need to find out what kind of distributor this is! It might be a stock Toy '71.
This is a link to Mallory catalog.
http://www.malloryperformance.com/CatalogsList.aspx?BrandID=6
See if u can find out if there is a name plate on this thing. Is there a condenser inside or outside the dizzy? Are the wires stock? How old?
I have OEM distributers that look like the two you describe. One has the post, the other has a screw. I have no idea what year they changed. The OEM number is covered up so either order from SOR or call Cdan.
treerootCO
That's the ticket! I'll probably go the Pertronix route eventually, but in the meantime adjusting points/timing/carb is better than meditation...
I ran into that same problem. You can get the correct points around town if you keep at it but I found it is easier to order them.
**Note** It is always good to check your oil pressure before and immediately after doing anything with your distributor. First engine I siezed was just after I replaced the vacuume advance.
