points adjustment.
Utah
I adjusted the points in my rig this weekend.
Theyw ere out of spec at .020
Dwell meter was showing an 22 degree dwell angle.
Spec is .018 with a dwell angle of 39-42 degrees.
I put the points back to factory spec, and my dwell angle is still only 30 degrees, and I have an erratic idle.
Truck starts, and goes down the highway just fine.
I figure that the Dwell angle has something to do with the erratic idle.
What can I do to fix the dwell angle?
I know, install a pertronix... Maybe after Cruise Moab.
Should I shorten the points gap to, say, .016?
Thanks!
Dwell angle is a much more precise measurement of what points are supposed to be doing than the gap, which is hard to measure in the truck, anyway. Your points may be irregular/burned. You could try closing the gap, filing the points and closing the gap, or replacing the points with a new set and then adjusting things. But getting the dwell angle correct should be your ultimate goal as far as figuring the points contribution to your issue.
If that's all good, it may also be that your distributor is worn and you have wobble, which will make it hard to have smoothe running.
The dist is about 2 years old.
Brand new OEM non-usa distributor.
FWIW, the shaft has no wobble in it.
The poitns have an irregular surface on them, and I have a new spare set. So I will try changing them out.
Thanks!
Love my OEM non-USA. Good luck!
I have never been able to get the dwell setting correct on my '76 with a points driven ignitor. Maybe it has something to do with the fact that the coil is electronically switched. Just set it to .018 and fuggedaboutit. The dwell angle is not a big deal on these tractor motors that rarely rev above 4,500 rpm. The timing will change slightly with a change in point gap, but other than that I doubt that it has anything to do with your idle problems.
