PO171 CEL?
Georgia
The CEL popped up so I ordered 2 new O2 sensors. They are installed. I cleared the code with the reader and it came on about 7mi later. What should I do? Disconnect the battery?
Cruiserheads: yes they are installed correctly... I have done it many times :)
that code indicates that the long term fuel trim has exceeded +20%.
Which means that the ECU is compensating for a lean condition by more than it should.
So you could have a weak fuel pump, crack in the air tube, bad or dirty MAF sensor, crack in the exhaust down pipe upstream of the front O2 sensor, a vacuum leak somewhere, clogged fuel filter.
Just to name a few.
how many miles would have to be driven since the o2 sensor install to get it to switch off?
Err...no amount of miles will get it to go off.
The issue was not your O2 sensors. See above for some ideas to the possible root cause. Once the actual issue is fixed and code cleared it won't come back on.
Clearly some diagnosis needs to be performed to see what the problem is. In the end this will also save you money as you won't be replacing unnecessary items.
Old thread but I got this code after a weekend bash in the woods, suspect the exhaust develop leak, plenty of rocks and boulders. What I did was cleaned MAF, check for intake hose issues, and visual inspect exhaust for obvious cracks, it all looked good. Then used shopvac to blow air into tailpipe and soapy water to look for leaks, here's the result. Will try to remove rusted old bolts and replace to reseal with new gaskets
After first cat flange, smaller leak
After second cat flange, major leak!
