PMS & Nipple
Manhattan, KS
Bingo!
:D :hillbilly: :D :hillbilly: :D :hillbilly:
Preventive
Maintenance
Service
Fumoto Engine Oil Drain Valve w/Nipple
Break to have :princess: shuttle me to CarQuest for addition to arsenal:
:hillbilly:
er...arent you worried about that thing snagging...against anything?
Ugh nm, I was thinking of the trans pan. Thats pretty cool but man would I be nervous as hell about that thing opening accidentally.
PMS Nipples are NOT touchy!
Engine Oil Drain Valve - Fumoto Engineering
Obviously, not something I've posted on PIRATE, but I've run Fumoto Nipple-style drain valves going back to early 90s.
The spring-loaded lever/lock has to be pushed in 2 directions to release, and takes some effort to do the 1st. I've run them on all of my rigs & never had an accidental release. I wouldn't recommend it for rockcrawling unless you have a skid plate to protect the valve, but in our use (no longer maintained, deadend Corpse pavement, gravel & dirt) the Fumoto is not a worry.
These 2 Fumoto nipples are off our now-gone old & new FJ62s. So the one on the left has well over 100K. Never once dropped into the drain pan. :cool: The lever on the right valve has been pushed into the release direction, but it still takes some effort to push further into the slot before it opens. Think of it as a Rubik's Cube for the One-Eyed Man.
They also carry a nippleless style, but that defeats the convenience of slipping a short section of hose routed into a jug for dripless draining. AND WHO WOULD'VE OPENED A POST TITLED PMS?
Hmm I think its a great idea so long as there is room and doesnt get snagged. I will be looking into this. Cheap mod to make my life easier.
Not intended as an insult but I think this is not necessary and possibly really problematic. It is so simple to crawl under the rig and remove the drain plug. Plus whether you are actually rock crawling or not all sorts of stuff rubs past that point and it isn't worth a loss of oil. I can see an application for a street car which is low and which won't see so much debris (hopefully) but putting this on an offroad vehicle even if it is only used for mild offroading just seems so risky. Again, not intended as an insult. :cheers:
My THANX to Buckru with his Post #22, which I have copied a portion of here as a means to shortcut why the One Eyed Guy aka 4XODDIC (allow me to pronounce that for you: 4 by, Odd Eye, See! ) has fixated on using a Fumoto, but has forgotten in his recent installation of one on an LX450 & removal of the 2 on his FJ62s when he turned them out to pasture.
I happen to have a fumoto on mine. Yes I agree that for hardcore wheeling it isn't appropriate. I have never worried about it even with moderate wheeling. But my uses for a fumoto are these.
1. Much easier to take a sample for blackstone.
2. I run synthetic oil and still like to drain a couple of quarts at 4k to freshen it
up for an 8k change interval. Try doing that mess free w/ a regular drain plug
3. If I am going to go on a hard wheeling trip, I like to drain the oil and put fresh
in anyway. That is when I put the regular plug back in. At my next oil
change. in goes the fumoto.
You can use a fumoto whenever you want or use the regular drain plug. It isn't one way or the other all the time. And yes, oil changes are a snap with these. I buy 5 quart jugs of oil and i can set an empty one underneath the fumoto and drain straight into it without the need for a funnel. A few minutes later I shut the valve off and stick a new jug under it and start draining the rest. No muss no fuss.
Buck
Not taken as one. If I tally up the miles, the experience exceeds 300K, without armored protection. Any obstacle has to pull the lever downward & then push (or pull) to end of slot. YMMV. Also not suggested for those folks asking for ideas on how to remove those simple, buggered OEM drain plugs. I have never sold a 4WD with a Fumoto, that's why I have 2 on hand (don't ask unless you have a 3FE). :D
I would likely hesitate doing figure 8s through some of our local ditchweed or K-WEED. I worked with a Co. Soil Conservation Agent who regretted BushHogging a barnyard of wild hemp. Not a mistake he repeated. That is what KS's WWII effort supported, other than Boeing, Beech & Cessna.
I think I bought my first Fumoto from John Baker Performance Products, of Dodge D50 4X4 racing fame, circa 1985. Have used on 4WDs only: D50, Samurais, FJ62s, Isuzu P'UP, Tundra, 4XODDIC & now LX450; so 300K is likely an underestimate, let's just say 25 years, again YMMV. And no, I no longer run K&Ns. :hillbilly:
I think it's less of a worry of the obstacle moving the lever and more of the obstacle completely ripping it off the truck. :hillbilly:
Good Points All: Fumoto has some answers:
Q. How much does the Engine Oil Drain Valve stick out from the oil pan? Is it safe to use the N-Type valve (with Nipple) for cars and light trucks?
A. The Drain Valve for passenger cars and light trucks is approximately 7/8" thick. This means that the valve sticks out only 1/2" more than the regular plug head from the oil pan. The Nipple on the N-Type Valve extends from the valve for 5/8". We do not recommend using the N-Type valve for vehicles with low clearance, as the valve may stick out too far against the ground.
Warning:
For users under extreme conditions:
If you are using the Engine Oil Drain Valve on off-road vehicles such as farm tractors and logging equipment under extreme environment (i.e. corn fields, brush areas), it is recommended that a hose clip as shown below be used for extra safety and security. The hose clip, which can be purchased at any hardware store, will firmly keep the lever in the locked position at all times.
The Engine Oil Drain Valve has been tested and granted "Genuine Part" status by six major motor vehicle manufacturers in Japan. These approvals were not granted easily and gaining them was a testimony to the quality and durability of the Engine Oil Drain Valve.
Oh, Mot! Can you source me a Genuine MR. T FJ (Fumoto) Engine Oil Drain Valve? :o
I'd guess the nipple could shear off the valve on a rock (valve wouldn't leak w/out nipple). But you're right, some folks spend a lotta $ for 0.5 inch of ground clearance. Then again, getting a crescent, or my 17 mm open end, wrench on the 7/8 inch high Fumoto is a snap compared to slipping a 12 pt. socket onto a buggered 3/8 inch OEM. :hillbilly:
Not challenging anyone to prove their point & drain a crankcase on the trail. Then again, don't hold onto your I told you so! card on my account.
I notice Fumoto doesn't mention Canadian Hemp Farms. :cool: I didn't find any testimonials from NASA, but then they didn't used to worry much about flying styrofoam. Mud concerns lead me to think about the hose clip:
The slot that the lever travels in seems like a nice place for dirt/dust/pebbles/sand/mud to hang out and gum up the works does it not? Also in the winter it could get full of snow/salt/ice. It's an interesting idea for sure, but I don't see the point. It normally takes me at the very least 1/2 an hour to change my oil and do all the other associated things, an extra 30 seconds to find the right wrench doesn't really bother me.
YMMV!
Here's a devoted site QuickOilDrainValve.com - the best way to change oil
or Engine Oil Drain Valve and Other Truck Parts and Truck Accessories by Performance Products 4 Trucks
Valves with nipple cost more.
I agree, most everyone's oil change time is quicker than mine, but I have the IQ scores to prove why I'm slower. :hillbilly: IF you're goning to have open heart surgery, have the tests beforehand, saves scratchin' your head 18 months down the trail. (See Bill Clinton & David Letterman for similar results.) YMMV
The last time I changed oil without a Fumoto, I watched in amazement as the oil drained out due to me forgetting to put the old drain plug back in. :bang: Flippin that lever would have been much quicker than me grabbing the plug & reversing the ratchet. :hillbilly:
Here's a couple of things I've added to my oil change tool kit over the years:
Fiberglass pallet, found in roadside ditch while looking for K-WEED (just kiddin' Officer Fife). Notice lack of spills when I use it!
Assortment of armament utilized in removing 90915-YZZD3 spun on by Alley Oop, Lincoln Lexus Grease Monkey. Extensions & swivels were used for torque wrench. Ratchet was enough once filter spun loose. Remember, I'm a 165 lb geezer. YMMV
Torque wrench from above, ratchet from below (skid plate removed = Honey, did you find a large, black metal plate in the dishwasher?)
Oh, the >100K mile valve above has never had the slot cleaned out. I normally use Synthetics, so avoid changing oil in inclement weather. Fumoto sends me a pkg of Ramen noodles for every oil change valve I can sell over Mud. Don't forget to reference 4XODDIC when you buy yours. :hillbilly: :hillbilly: :hillbilly: :hillbilly: :hillbilly: :hillbilly:
I'm sold with the clip solution. MOT!!!
Anyone relying on the clip clearly isn't into real rough wheeling; I only consider myself capably "moderate" as a wheeler and I've got good scratches all up and down both the oil pan and the tranny pan. I've pulled everything from mud to sand to snow to soil and sod to sticks and rocks and .... out of every which way it can get into after wheeling. I even stripped my tranny pan's drain plug on a really mild wheeling going over one large earth mound. Again, I'm only a moderate wheeler and don't do half the stuff that some folks here do daily almost. Still, i'd never rely on this thing. I mean fifteen seconds for loosening the plug and you're good to go. What's takes the time you're trying to save here? Anyways, I'm not trying to insult the thing, it just isn't worth the small time savings for all the added risk. JMHO. :cheers:
That's why you need my skid plate (at least for the tranny pan). :cheers:
Incidentally, a full coverage skid plate would also protect this, at least on the tranny. I don't really see a way of fabbing up a decent plate to protect the oil drain, it's too low.
Exactly! Even the shear force from breaking off that nipple nub would likely stip the threads of the oil pan out; like I wrote, I only rounded off the drain pan plug on my tranny and it stripped the threads to the tranny pan. A full belly skid plate would help here but even then it would work easier to reach the regular plug with a deep dish socket then to try to wiggle yer fingers up through the access hole and rotate and lift that lever there for the nipple thing. I'm just sayin for the record this isn't the right thing for our rigs. Anyways, :cheers:
Ohh, yes your skidplate is suweet! :cheers::cheers::cheers:
fifteen seconds for loosening the plug and you're good to go. What's takes the time you're trying to save here? it just isn't worth the small time savings for all the added risk. JMHO. :cheers:
I would have to agree with your observations for 70% of the population (NOTE: I said Pop. not those on Mud, nor LC owners in general).
~ 18 months after open heart surgery, I experienced
Pump head - cognitive impairment after bypass surgery. The impairment can take any of a number of ways to slow a person down. In my case, having been blind in one eye for 17 years at that point, my brain began to fool itself. As my perception of vision slowed down, my brain compensated by providing a mental image of what it thought I was seeing = shortcut.
Try this grade school trick: Hold your thumb out at arm's length. Looking at your thumb, close one eye & then the other. What did you just see happen? Did that really happen? Which do you believe, your eyes, or your mind?
I'm guessing you experienced mind over vision. Now imagine your brain shortcutting your interpretation of everything you see.
It's taken me about 8 years to compensate for my Pump Head, I expect to keep learning compensation tactics as long as I live. I use a # of crutches to function, but am still slower than ~ 35% of the Pop. in interpreting vision & completing a task. I have decided to have front axle service completed by a shop; but am patting myself on the back today for changing my own oil. I even called my :princess: at work to tell her I'd gotten the filter off.
I'm not trying to convince anyone to slap on a Fumoto (I find Ramen noodles too salty). For my type of 4WD use they've worked. They're familiar to my memory, so I don't have to decide whether to trust my vision (mind) when I look at one. For the same reasons, I like sticking with Toyotas, even went so far as to buy a 2nd FJ62 to avoid learning to drive a different LC. And Yes, I referred myself to DMV to take a driving test again. Officer Fife wasn't sure why I was taking the test voluntarily & that I was A-OK. I let the :princess: do 90% of the driving. I sure enjoy my 10%.
I respect your opinion, and don't doubt why you would question mine. As Einstein would say, TIME is relevant to one's perspective.
Happy Trails!
:hillbilly:
Happy Trails!
:hillbilly:
Jeepers, Joe, I didn't realize any of that or that this valve actually helped you pursue the pleasures of wrenching on your own vehicle. I'm sincerely sorry for ragging on it if it sounded so. Its really an application specific thing and I acknowledge that the application you want it for is perfect for you. Its also perfect for 95% or more of the vehicles out there on the roads. I also admit I'm much more paranoid than most which is why I always insist on a new drain plug washer with each drain & fill, always torque the plugs to precisely what the FSM says, always look under the rig with each fuel fillup for little leaks, and almost always measure the oil that drains out of my pan and my catch cans after each drain & fill to verify there's no loss of oil. Basically anything and everything I can imagine might go wrong I do something specific for. Its called paranoia, it sucks. So please pardon me for this whole thing; like i wrote already it was never ever intended as an insult but I feel extra sh**ty knowing now that this valve helps you maintain your rig and I'm sincerely sorry for that. :cheers:
Oh No, don't feel that way at all. I don't. I'm slow at posting, so you & Ebag333 posted up while I replied. Didn't mean to blindside anyone (pun intended). And of course, I got hooked on Fumotos before mind games era. ;)
That's a great way of expressing it, as in Zen & the Art of Land Cruiser Maintenance (Geeez, I haven't read that book in maybe 25 years. LOL = Zen & the art of motorcycle maintenance : an inquiry into values by Robert M. Pirsig (Used, New, Out-of-Print) - Alibris)
I have accepted my half-:banana: limit as a challenge, not to be overcome but just to take in stride. The LX450 first-time oil AND filter change went pretty smoothly, other than getting the filter off. :bang: :bang: Most of the :clap: resulted from not resorting to vocabulary instead of :wrench:, which :princess: won't tolerate when I've asked for help. (Why is it women don't understand cursing at an oil filter is nothing personal?) :D
I like the idea of the full belly pan. All the posts have been appropriate, don't get the idea I've taken any offense. I can't explain why the Fumoto isn't jammed with crud, seems like it would be, as I don't shy away from muddy roads or snow, that's the point of 4WD for me. Honestly, I don't offroad, although some of my favorite (abandoned) highways now have tallgrass prairie growing up through the pavement.
When (IF) I get one or both of the Samurais back on the road (goal is before snow flies so :princess: can park LX450 inside, last winter I had to warm up & scrape windows on her FJ62), I intend to get a little more adventurous.
Tomorrow, with the help of Mud posts (past & future), I intend to accept the challenge of #6 plug!
:hillbilly:
Joe, in the hope it helps, I noticed your comment about the oil filter and accessibility. I was going to give a suggestion that once on your rig might further help you enjoy the pleasures of wrenching on your own rig. I'm going to give a link off of Christo's site but I would think that any capable local mechanic could help you here by installing this system once and then give you great access to the oil filter from the front of the rig and without having to reach up to the block to twist the thing off. Again, just in the hope it helps.
Slee - Oil Filter Relocation (Toyota 80 Series Land Cruiser)
PS. I admire your determined desire to do these procedures yourself man, that's totally cool and probably pretty therapeutic in many ways. :cheers: to you!
