when bleedin only saw air in LSPV, i did the bleed seq in par to what is stated if FAQ
If you see air from the LSPV, then you aren't getting any/much pressure (to speak of) to your rear brakes. While you do stop mostly with your front brakes, your rears make a significant difference in your stopping capability.
when i was backin off trailer brakes wouldnt hold from slamin front bumper into trailer.
Your towing a trailer with soft brakes?
Are these only problems when towing? Or all the time?
What 2 checks are you referring for checkin the brake booster.
At this point it doesn't matter because from what you've told us the brake pedel is all the way to the floor. Until that's resolved the BB checks (which require that the brake pedel
not be on the floor) can't be done.
Well from talkin to PO only brake related thing hes dont is new front remaned calipers and slee lines for the lift
Your Slee lines might be letting air into the line, it's been known to happen (usually from improper install, lines getting pinched or rubbed, etc).
If you're seeing air from the LSPV, check the lines that connect to the LSPV for wear/pinching/damage/etc.
im contemplating gravity bleed
Gravity bleeds are for trailers, they won't work for this purpose.
Either keep bleeding the lines until you don't have
any air in them or take it to the dealership or another mechanic who can power bleed them. In your case it may end up being cheaper/easier/safer to take it in rather than doing it yourself. Especially with the LSPV it's very easy to let air into your lines through the bleeder screw.
I used nearly 3 quarts of fluid to get all the air out, but a fair amount of that was wasted due to me cracking the LSPV bleeder screw open too far (and letting air in).
