I got a crack in a cast iron plumbing drain pipe in an unfinished basement. The crack is at the bottom of the pipe and water is currently dripping overhead so access is not an issue. There is a Y connector in the in the vicinity of the crack so replacing bad section is not easy. I could call a plumber to replace the section but since it is an unfinished basement I don't really care if it is repaired by an expensive plumber now because I could just let the water go down the floor drain if the repair fails. Since the fluid is not under pressure I think it should be an cheap easy fix for as little time invested. Before I waste my time going down the wrong route I would like your suggestions on how you would fix it. My experience in plumbing only involves putting sinks,toilets, dishwashers and other finished work, not so much rough plumbing.
The question is what would you suggest?
JB quick?
Hydraulic cement?
Weld? have equipment but can I do it to cast iron and will it screw up anything attached to plumbing-phone lines, dishwashers electronics.
shove a bunch of clay into the crack
strap a rubber sleeve?
etc.....
thanks alot for the suggestions.
JB quick?
Hydraulic cement?
etc.....
