Plumbing-faucet. Wuestion.
Hot Springs AR
Diverter knob broken so I'm tring replace tub faucet. How do I remove this ? I need to get back to copper line to install new faucet.
should just slide on/off...may, twist....but I think it's a pressure fit
looks pretty calcified...take some apple cider vinegar and clean it up
will it pull out of the tub any further? if yes, heres what i would consider: put some needle nosed vice grips as far back as you can on the tubing to prevent it from sneaking back up into the tub. then cut off the fitting leaving as much exposed copper pipe as you can. if you need to extend the copper back out you could sweat on an extension, or just work with what you have if possible.
No closet on the backside. Most of the replacement faucets at the store have threads in a different position and come with their own plastic adaptor that needs to go on a clean pipe.
Looks like Delta to me. I just installed a tub spout with the same piece. It's soldered on - I had to solder mine.
It's made to be universal to several different Delta styles so you can interchange them, I think.
Probably won't fit any of the universal replacements out there.
That is Delta and it is soldered. You can heat it and melt the solder to get it off or you can get another Delta spout and thread it on. Personally I would go to a plumbing supply store and get a Delta spout. Sorry I was late to the party.
