Plugs/cap question. (40)
MrMoMo
That's not rust, it's Canadian patina...
~Kingston, ON, pero soñando de Panamá
Ok, put new OEM plugs, cap, rotor and wires on my '76 40. When I put the new cap on it did not seem 100% tight at the front (where the springy clip is.) I also noticed that the front is where plug wire for #5 comes off. My #5 plug was a bit odd looking (puffy white blisters on it - will post pic in this thread as soon as I get it downloaded) I also get a bit of a hesitation every once in a while while driving.
So, my question is, how likely is it that these are all related, and should my dist. cap be a pretty tight fit, or is a bit of a wobble OK? If I bend the clip will it tighten or am I missing something like an O ring or gasket? - just didn't quite seem right...
There also seemed to be a fair amount of oil on the threads of this plug (only this one) Is this a bad sign? I don't remember the plug being overly tight, could it jut be that it was loose and oil was migrating up the threads? Only had this truck just over a month so I don't really know if I am burning up oil (doesn't smell or look like it)
Thanks.
Oh come on, no-one out there has seen a plug like this - someone tell me what's up!!
Whats the wet/dry compression numbers?
Havvn't checked the compression numbers, don't have my own tester, I think the plugs were maybe too hot? They were not ND plugs and I think they were over gapped as well....
