I'm wiring up my headlights and dont know which post on the back of the headlight is the ground. It's a 66 FJ40. There are no wires going to the headlights now (long story) and I'm just hooking something up quickly to get me to work for night shift.
Thanks in advance!!!!
If you have a multi meter stick both probes into the connector till you get a reading and see whether it reads positive or negative to find out which ones the earth.
It reads a negative 12v then you have the red probe in the earth, if it reads positive 12v then you have the black one in the earth. one lead should give no reading at that will be the high beam which is normally off!. Sorry i cant be of much more help right now, i'm not near my car.
Ps. in an emergency you can always use the body as earth or run a couple of leads straight from your battery to get you to work, but dont for get to turn them off!
Hopefully some one else might post a picture for you
I dont have a meter, but I DO have a set of wires coming straight off the alternator, and a couple of pigtails straight to ground on the fenders. Can I just try different combinations or will it jack up my headlights?
you shouldn’t blow your headlights by just hooking them straight to live wires temporarily, even if the terminals are hooked back to front, they don’t care which way the current flows. just make sure no live wires go straight to the body and you should be fine. what has happened are you fitting different headlights and the connectors don’t fit? can you post some pics? and i'm assuming of corse that you have a 12v system feeding 12v lamps!
you shouldn’t blow your headlights by just hooking them straight to live wires temporarily, even if the terminals are hooked back to front, they don’t care which way the current flows. just make sure no live wires go straight to the body and you should be fine. !
This is correct. There are three terminals and 3 wires. Just try it by trial and error until you get the low beams and high beams to work correctly. There are 6 possible combinations.
