please help
Libya
Toyota Landcruiser series 80
Model 94
I thought about what I would swap into mine (LJ79) if I had the chance. I think either a 1kd or 2 kd engine. The 1kd is the 3.0L with variable geometry intercooled turbo, the 2kd is a 2.5 turbo non intercooled engine. Both are common rail. Would they be more powerful and faster than a LS? No way, but I think it would have the cool factor. I believe you have the R151 tranny stock, which are still being used with both of those engines. So with the correct bell housing, it would bolt right up.
Wiring would be a job, but I can't imagine anymore complicated the a fuel injection LS.
I think you can pick them up on eBay for about $3000.
Just my two cents...
A442FT transmission
When starting work, I put the
lever on (D) the car moves very slowly, as if it is on number (3) I put it on L, it moves quickly, and I put it on (D) it moves very normally
