Please help...tracking down oil leak.
Jupiter, FL
I'm hoping a few trained eyes will make this an easy one. While replacing all 4 TREs (Three-Five brand), I decided to clean the underside of the engine to try to find the origin of my oil leak. I took a few pics about 10 miles after the cleaning:
Notes:
1. VCG needs replacing, but cannot be the source of all this oil.
2. Oil/grime covers the entire front of the engine, from valve cover to oil pan.
3. 3 of my 4 TRE's were movable by hand..much tighter now.
4. Pickle forks ROCK, if you're replacing and don't have to worry about boots.
5. Distributor o-ring was replaced last year.
6. Steering box adjustment made things even better with the new parts.
Pertinent pics are the last 9 on the page, and yes, damage multipliers are GONE.
PictureTrail Gallery
I know some pics won't help much, just snapped a bunch before work from many angles.
Any info or advice will be greatly appreciated.
I would replace your front cranks seal and oil pump cover o-ring. That seems to be where the leak is coming from.
Try searching for oil pump seal replacement and you should find some useful threads
Agree with 94Srunner. That's a pretty good leak and it looks like it's coming from the oil pump seal. What's all the silverish goop around that area (did the PO try to mask it with some FIPG?) Make sure that is motor oil (from the pics, it looks reddish so just making sure it's not ATF fluid spewing from maybe somewhere else <- not likely)
There is a link in the FAQ (Zane's thread) on how to do this. One thing to consider is you will need some way to torque down your crankshaft bolt to 350ft lbs!
Would like to know if you tackle this as i'm in the same dilemma as you but my leak isn't quite as bad.
I to am in need of this, but my leak is very minor a small drip area is left in the parking spot after shutting down. I loose about a quarter quart every ten days. Not bad in my opinion, but never the less it needs to be changed. But I just haven't been able to track down such a monster torque wrench.....
I'm in the same boat as you. I was quoted ~$370 to have this done at a local shop (not dealership) but it pains me to pay so much especially when the parts are probably less than $25 bucks. I was thinking about using the handle of my floor jack and just cranking it down that way (i hope i dont get flamed for saying something like that) but i too, have no idea where to find/borrow/rent that kind of torque wrench.
Clean it up good and put some dye in the oil and buy one of the $17 leak detector kits at NAPA.
-B-
I would definitely be sure to clean the engine REALLY good before I finished inspecting. I thought I had a really bad leak...but it turns out most of what I thought was a leak actually is spilled oil from my filter. I haven't perfected my oil change yet.
BeowUlf has the right idea with using a leak detection kit. You really want to be sure where it is coming from. How much oil are we talking about? a few drops a week?hour?minute?
I'll definitely clean the whole thing before I start ordering parts, just to get it all done while it's apart. I lose maybe one drop on the driveway, so I'm sure it only really leaks when the oil is under pressure. I may lose 1 quart per 1K miles. My daily commute is 4 miles one way, so it takes a while to drive a thousand miles and I lose track of how much oil I've added.
-B-
Thanks, Beo, I'll do that before all is said and done.
No idea what the silver goop is, but was probably a band-aid attempt. It's definitely oil, my only trans fluid leak is between the upper and lower dipstick tube...o-ring has been in the garage for months. I'm lazy. From what I've read, that crank bolt scares me. The other parts of the replacement look easy enough.
Thanks for all the replies, guys.:cheers:
You need to clean it better than that if you want to see where the oil is coming from and not guess.
How much did you adjust your steering box? Did you replase the washer/seal after?
Even with the drag link off it seemed like guess work on making the adjustment without removing the box. Just wondering how you went about doing it.
In my opinion that is the oil pump leaking. The belt then sling it all over the place. Depending on the state of your cruiser replacing that thing can be a huge pain. When I did mine five screw heads stripped. I had to drill them out. Beyond that the task inandofitself is not that difficult.
Karl
Karl
The LC has been in south FL all its life, so I think it's probably in stellar condition...under all that oily crap. The engine bay is quite clean, other than the leaks.
I'll definitely get all the crap off before beginning. I hate having to double-dip because I didn't get all the parts in the first place. I didn't replace the washer, and I only adjusted about 1/2 turn. I may adjust more, just not enough to bind. After new TREs, new bearings, new shocks...the steering box adjustment made the biggest difference in how she drives.
NAPA Item#: BK 7656010
They also sell dye that is specifically for the engine oil. The dye is about $5/bottle. The UV kit is about $17.
-B-
I'm just adding oil right now. It's just not a huge issue since I drive ~7 miles/day. It'll be done next winter, I suppose, when perfect weather's back.
