Please HELP, lift issue
New Hampshire
Well, thanks to all you have given me advise in the past. I purchased an OME 3" lift and put it in this evening. But, however there were NO directions included and when my friend and I completed. The LC was leaning to the left. Four (J) series springs, 2 front labeled A and B. I put A on Drvr side and B on Passgr side. Same scenerio with the rear springs. Now the Passgr frnt is 1" higher than the Drvr. In the rear the Passgr is 2" higher than the Drvr. Please help me figure out what possibly could be going on. I am certain that all springs went in correctly.
Again please help me. Currently frustration is out weighing what should be emense joy right now. Thank you very much in advance.
Derek
It sounds like you have the springs on the wrong sides. The taller springs go on the left side (USDS).
Can you visibly tell
I looked at the springs and I couldn't tell that one front was taller than the other. Same with the rear. How can you tell?
Set them side-by-side. One spring will be a bit taller than the other. I think it's about 3/8 of an inch or so. I don't remember exactly but when they are side-by-side you will be able to see the difference.
Derek, did you get this fixed?
Hey Guys
Hey everyone. Sorry it has taken so long to respond. i was having some computer problems. I guess I can't get a break. Yes I got the lift straightened out. I just switched the springs to the other side as suggested and Perfect. Thanks again for the help.
