- Joined
- Aug 15, 2005
- Threads
- 776
- Messages
- 5,125
does the right side TRE have the same width and pitch as the pitman TRE?
New question, I want to use the right side (passenger) TRE for my pitman TRE. Are they the same width and pitch?
Becasue of my tie rod length, the factory pitman TRE is too long. Will the driver's side TRE fit into the pitman arm opening? Or is the pitman opening larger than the other TREs on a 60 series?
If 4x4 labs has an adapter that will work with a 40 series TRE (smae width and pitch as an 80 series). I will go that way.
Thanks for the responses.
THis answered: I am installing an FJ60 steering into my FJ40. I was going to use an extra 80series TRE sine I thought the tappered jole in the pitman would be the same as in a 60 series. Nope. 60 series is wider on my pitman and wider than a 40 series TRE.
Before I go and order a new TRE, can anyone confirm if the tappered hole on the end of a 60 sereis pitman is in fact wider than a 40 and 80 sereis TRE? I ask since the pitman may have been reilled out prior to me getting it.
The second question, do I need to use a left had side TRE with the stablizer hole on the pitman, or will a passenger side TRE fit into the hole on the pitman? I do not need the added length of the stabilizer side TRE.
Thanks.
Thanks.
